Snowlar Panels and a slightly off topic use for surplus energy
#31
(02-06-2019, 06:50 PM)chuckp Wrote: Yes buddy.
Electrical, Plumbing and Heating technician, almost 35 years in.
I knew it.
So I'm sure everything I wrote above is total gibberish.
I can fix your car and I can fix your network but plumbing I leave to a real professional.
Every time I have soldered some pipes together I get soaked usually I forget to turn the water off somewhere. Dodgy
#32
I knew it.
LoL
You're not that far off the mark.
As soon as I can put some pics and drawings up you'll follow it no problem.
I work mainly in industrial/commercial fields. Occasionally I get an easy day and do some domestic work.
Sometimes we can't help but get wet, even the best of us can isolate the wrong valve once in a while. LoL
We had a domestic plumber in our village who's nickname was Leaky Len, he was renowned for causing floods, usually because he'd forget to cap an open end somewhere before filling the system.
UK Southwest.
#33
(02-06-2019, 12:53 PM)Wolf Wrote: Yes i would like to see some diagrams when you have time.
A basic schematic of my system at home, heating and hot water. I've emitted a few items for clarity, IE. zone valves, controls etc.
I can give you more info on how it's connected up if your interested but it shows the basic layout of the tanks, pipe work etc.
My Solic 200 is supplying the bottom 3 kW heater in my Heat Bank and the 3kW heater in my pre-heat tank via a change over contactor so that I can switch back and forth between the two.
UK Southwest.
#34
A basic schematic of my system at home, heating and hot water. I've emitted a few items for clarity.
Thanks Chuckp
I will study it and when I see my plumber we will discuss it and see how this would work with my system.
Thanks again for sharing this with me.
Low production day today 0.9KW Snowlar day.
#35
Thanks Chuckp
Mine was like that yesterday 0.74kWh. Generation today was 2.98kWh.
Luckily the snow only lasted a couple of days here. But it has been very wet with dark clouds since the snow fall.
Funnily enough i came across an old install today in a pool plant room that's utilising the same flue has heat recovery unit as mine.
This is what it looks like. This one is doing hot water only, but the principle is the same, omit the flue gas heat recovery unit, fit a solar supplied immersion heater in the pre-heat tank and it would work the same way.
This tank has a couple of coils in it for segregation purposes. They are also using a feed from the heating system for pasteurization.
Sorry this thread has gone a little of topic with all the plumbing and heating talk, the intention is to show how surplus  PV solar can be incorporated into hot water storage systems.
UK Southwest.
#36
Another low day for generated solar power. Managed 2.15 kWh, however we've had rain and dark clouds all day.
UK Southwest.
#37
3.6 so far got another hr to go.
Sunny cold and windy.
#38
Slight increase again today, managed to generate 3.19 kWh, still have about an hour of light left.
Don't think it'll produce much now though.
Dry and cloudy today with sunny spells.
UK Southwest.
#39
Managed another slight increase again today over yesterday. Generated 3.43 kWh.
UK Southwest.
#40
Month so far Saturday was the best.
Today 2.9Kw
chuckp likes this post
