Multiple Sun-1000GTLI inverters and Monitoring
Anyone have multiple SunG 1000 or 2000w inverters setup and are monitoring them?
I have two Sun-1000gtli for each leg of my electrical panel, split phase (in us).
I do not have the wi-fi units and was thinking of getting them but the cost seems steep given the cost of the inverter, $70 vs. $250.
What are folks doing? My inverter manual lists a 'wi-fi rtu' unit that supposedly can monitor multiple inverters but I have been unable to find it available for sale. That would be ideal vs. buying two wifi plugins.
wi-fi rtu
Thanks
Has anyone extended the limiter clip on sensor cable?
I wonder how much long it cold be without giving bad readings.
Ive got one but i have it disconnected at the moment and plan on getting a second one
so i hope someone has an answer to your question !
(02-14-2019, 04:38 PM)Solardad Wrote: Anyone have multiple SunG 1000 or 2000w inverters setup and are monitoring them?
Solardad.
As you know I do have just one GTIL 10000 and I did get the Wifi module to monitor it.
It works great but I will be using the IoTaWatt for future monitoring as it will monitor my Grid usage and my Output from the GTIL 1000 along with 10 other circuits.
BTW I will be getting another GTIL 1000 just like you and instead of it feeding both legs of my grid right now I will split them for more accurate L1 and L2 power distribution.
(02-15-2019, 04:39 AM)Gato Wrote: Has anyone extended the limiter clip on sensor cable?
 Gato,
Yes they can be extended as long as you use a shielded cable. It needs to be twisted pair with shield. Instuctions on how to do it are here https://learn.openenergymonitor.org/elec...g-ct-cable
Solardad likes this post
Last count as of 8/7/2019
For Info Google Drive
Not your average Wolf
            Cool
I read somewhere 30m is the suggested max. You could just do a test to confirm. I recently bought some larger ct clamps, 16mm, to be able to monitor my main panel, about 70’ from the inverters. I’ll send out an update once installed.
Solardad.
 Gato,
Hi wolf - I actually have my two on separate legs of my sub panel and not one monitoring both legs (which I think is not possible).
I may get two more and have two per leg, similar to this setup:
https://youtu.be/zVZPz9Kt8n8
Good luck with the iotawatt
[url=https://youtu.be/zVZPz9Kt8n8][/url]
(02-16-2019, 11:54 AM)Solardad Wrote: Hi wolf - I actually have my two on separate legs of my sub panel and not one monitoring both legs (which I think is not possible).
I Plan on doing that to. 1 CT per GTIL
            Cool
it has rs232 port any one grabbing data from these out puts and displaying using raspberry pie?
43 User(s) read this thread:
saddizdd7 (05-20-2019, 12:27 AM), engarom (05-08-2019, 07:11 PM), stevelectric (02-16-2019, 10:39 PM), Solardad (04-22-2019, 02:31 PM), Generic (04-21-2019, 03:20 PM), Wolf (05-30-2019, 11:55 AM), sl1me (08-28-2019, 04:35 AM), Truth (04-30-2019, 01:09 AM), hazSolar (04-08-2019, 03:17 PM), ajw22 (02-27-2019, 03:40 AM), RikH (04-27-2019, 04:39 AM), LEDSchlucker (02-16-2019, 01:22 PM), foamovercast (06-03-2019, 08:31 PM), BitcoinBandit (04-22-2019, 01:27 PM), Owen96 (04-22-2019, 10:44 PM), Gato (02-17-2019, 05:03 AM), rearden (05-13-2019, 09:18 PM), Edster (02-15-2019, 12:51 PM), Mexx575 (03-02-2019, 06:25 PM), Richard (04-21-2019, 07:40 AM), emuland-metroman (04-21-2019, 06:56 AM), Powermad00 (02-16-2019, 12:06 PM), Kevin Mason (02-16-2019, 05:29 PM), Geek (02-18-2019, 02:08 AM), watts-on (04-21-2019, 07:57 AM), wim (02-17-2019, 07:42 AM), A + A (02-15-2019, 07:48 PM), Korishan (02-16-2019, 02:19 PM), mike (02-19-2019, 01:55 AM), Sean (04-21-2019, 07:38 AM), daromer (02-16-2019, 01:59 PM), Menno (02-15-2019, 10:25 PM), ChrisD5710 (04-21-2019, 08:09 AM), Oz18650 (04-21-2019, 04:10 AM), chuckp (02-16-2019, 06:17 PM), michael620 (02-15-2019, 05:14 PM), jonyjoe505 (02-15-2019, 02:42 AM), kanchana (05-28-2019, 01:37 PM), gpn (02-16-2019, 02:44 AM), djuro (02-14-2019, 05:45 PM), Filip (04-21-2019, 03:31 PM), shonalex (04-21-2019, 06:21 PM), hbpowerwall (02-15-2019, 10:05 PM)
