thanar
- Feb 12, 2018
- 155
This project took some time, since I'm mostly crazy-meticulous about anything I do and this has also bubbled over into my hobbies. I started gathering laptop batteries around a year ago and havegone through just around 120 of them so far. It's somewhat difficult to find used batteries in Greece, let alone for free. I have spent around 90 for the batteries so far.
Here's a link to myon-going harvesting spreadsheet. I basically started it so as not to lose track of the cells, in case something would go wrong, I would have better chances of knowing the condition of the cell in the beginning.
I started this project mainly "just because", but also because I built an e-bike around the same time, and because I had access to a few used solar panels from my job's secondary activities(I am a Surveyor Engineer).
Basic goal was to build a 7s battery. Started sourcing laptop batteries with the first goal being to put together 7 20p bricks, as I've been seeing on all these videos around. I would be OK with nominal 1400W that the battery would be able to provide. However, since I am almost at 200 cells that have passed my thresholds, I will be going for a 7s40p battery.
While on the "my thresholds" issue, I should note that I am testing the cells at 1A discharge, they usually stay for 15 days (minimum) to test self-discharge, and I only keep for the main project the cells that are over 70% of their original capacity.
All other cells go into the "<70% norminal" spreadsheet tab, they get a second discharge test at 500mAand that's actually the cells that I am using into the "Solar Tower" project, that is, this one.I am using Jehu's boards (hence the "tower") and been swapping cells from time to time, in order to be using the ones with the greatest capacity (that of course are below 70% of norminal).
So, here's my setup so far:
I am currently using the abovesetup to charge my e-bike (which has a minuscule 140Wh battery), as well as my "Giveaway Powerbanks" I am building out of the worst cells,but it will soon grow to include the following as soon as the stuff I ordered a couple of months ago finally arrive:
[*]another DC/DC converter to power a laptop I have laying around in the shed, if it doesn't work on 12V DC
[*]a cheap true sinewave inverter to be able to run a couple of other stuff (TV, 220VDC lights and stuff)
[*]something else I am forgetting right now for some reason
I will be building my next "Solar Bricks @40.3,21.8" project as soon as I get to 280 cells.
Please let me know if anything is far off... Also happy to reply to any questions.
- 3x 90Wp thin film solar panels in parallel that only give out 180W in total, because they are old
- aVictron 100|15 controller
- 10x Jehu's boards populated with my "<70% norminal" cells
- an AliExpress"Smart BMS" with bluetooth
- anMPT7210a used as a DC-DC converter to 41V for my e-bike
- abuck converter down to 12V to run a few lines for LED lighting (internal and external), the iMax charger and another Maha one.
- abuck converter down to 5V for USB power
- a panel 12-24V USB-c + USB QC socket with display
