Hi, Friends!
Does anyone have experience with battery bank projects using intact laptop batteries?
I've come across a big load of almost-spec laptop batteries. I've disassembled and tested 10 battery packs (6 x Panasonic NCR18650) and they range about200mah below spec(2800mah).
Instead of removing and building my own battery packs, I have been looking for the female battery plugs. My idea is to wire them all parallel to a bus bar. Output is 10.6V at 5.7Ah, step up to 12V and run an inverter.
Ideas? Thoughts? Bad advice?
Much appreciated!
Much appreciated!
