Moderator
- Joined
- Sep 25, 2018
- Messages
- 2,004
Alright I have recorded 2711 cells in my spreadsheet and on my way to 3000 plus. Where it will end no one knows. It may not end at all although once I get my 14s200p wall built it will probably slow down some.
So I have been having fun with excel and have built a "Cell Calculator" that pulls data from my main sheet and filters it according to mAh per cell Then refilters to >80% capacity.
In other words enter the minimum mAh per cell required in your pack and it will spit out the results of how many cells that have been tested that have that resultorgreater. It also calculates the average mAhs of all the cells and then can multiply that by the number of p which will give you the Ah of that pack. You can adjust the max cell V, # of strings and then calculates the kWh of the whole pack.
So I did some scenarios with 2000mAh to 2300mAh entered.
I may change my mind now and go with as low as 2100mAh cells. First of I have a lot of 2200mAh rated cells that are testing at >80% of capacity mostly much better 90%+ but that is in the cutoff area of <2200mAh.
I have also added the IR calculations as a side benefit for those that are interested.
I can say this much as my IR investigation continues, I can just about guess what the capacity of a given cell is going to be just by the initial IR measurement alone. But I digress.
Here are the results of 2000mAh to 2300mAh pack calculations. Interesting to see that between theminimum per cell from2000mAhto2300mAh the total increaseis only 1.73kWh.
So with this information would you reduce your cell requirements to 2000mAh or as I possibly plan to 2100mAh or would you hold out for the jackpot ofall at least 2200mAh? I am itching to get started on my cell packs but I also want the best possible cells. So the dilemma continues.
