Good Chinese BMS review
(03-07-2019, 06:30 PM)Ebarnett Wrote: Thanks Sean, I've see some other posts recommending 4.0 as the max charge voltage to help with battery life.
SOC vs voltage is not a linear function.
1 kWp in Test
Ultra low cost
(03-07-2019, 05:21 PM)Ebarnett Wrote: I hate to ask a stupid question but I'm going to.  Ajw22, you mention charging to only 90% of cells max voltage.  On a battery with a Standard charge of .5C of 1500ma and 4.2v wouldn't the max charge voltage need to be .9 x 4.2 = 3.78v per cell.  How did you come up with 4.05v.  That comes to about 98% not 90%.  Please show me where my math is incorrect.
Thanks.
It's not really based on maths.  What one can do is to look at a charge or discharge graph for that chemistry like this one:
https://learn.adafruit.com/assets/979
and look up the Voltage vs DischargeCapacity at your desired C rating.
Temperature, battery model, internal resistance (esp with older cells) all throw this off, so you should expect an accuracy of at best +/- 5%.
Just to correct your _math_: you need to consider that the usable voltage range is 4.2V ~ 3.0V .
So the calculation should be 3.0V + (4.2V-3.0V)x90% = 4.08V
But as Cherry67 state above, this would be a very poor approximation because "SOC vs voltage is not a linear function."
Excellent thanks.
This china bms together with victron multigrid does it all. Multigrid does cc/cv and can also control Eltek flatpack2 chargers via can bus in order to increase charging current. Therefore bms does not need to control charging process...
Yes it does. The Victron does not know about individual cell voltages. It only knows about total voltage.
(03-16-2019, 07:53 AM)Charly144 Wrote: Multigrid does cc/cv and can also control Eltek flatpack2 chargers via can bus in order to increase charging current.
How ?
Can it request a lower charge rate when cells are in bypass ?
Yes, multigrid lowers amperage when defined voltage is reached. As well for itself and the flatpack2...
(03-16-2019, 01:30 PM)Charly144 Wrote: Yes, multigrid lowers amperage when defined voltage is reached. As well for itself and the flatpack2...
Charge current will naturally taper towards terminal voltage - could you explain how the Multi talks to the Eltek via CAN please ?
#29
I have no details on that but victron confirms integration with flatpack2...
#30
(03-16-2019, 02:47 PM)Charly144 Wrote: I have no details on that but victron confirms integration with flatpack2...
Could you provide a link please - specifically the CAN control.
