Powerwall build from recycled LiPo prismatic cells
I managed to score a bunch of LiPo prismatic cells very cheap, and intend on putting them together for use as a powerwall. The cells are Sanyo UPF3976108, they are rated at 3880 mAh each.
They are in sets of 2 in parallel and I am unable to separate without damage, so i am planning on making modules that are 13S2P, like this:
I plan on connecting the cells with 2 x 1/8w resister legs which should fuse at around 10amp.
Looks like it should work nicely. What will you be using this for btw?
(03-19-2019, 01:53 PM)Rossebaugh Wrote: Looks like it should work nicely. What will you be using this for btw?
I am currently running a home server, that needs to run 24/7, so will initially just use it for that, it only draws 200W at the moment.
I plan on building a firebox, so that each 13s2p battery is isolated from the next one, and to contain it in case it catches fire.
I finally took delivery of my batteries, now comes the disassembly and testing of each cell. I get limited spare time, so it's gonna take me a while. I think I have enough to make a 15kWh battery, but time will tell (I am sure there are some bad / damaged cells)
Very interesting! Our good old 18650 is definitely disappearing from from laptop battery packs...
After some dissassembly, this is what 0.9kWh looks like, very compact, only 23 x 11 x 8cm
Constrain them before you charge them.
(04-13-2019, 07:28 AM)Sean Wrote: Constrain them before you charge them.
I have been given mixed advice on this, from give them room to expand (space the cells apart), to keep them under pressure
86 User(s) read this thread:
runsnbunsn (03-19-2019, 03:30 PM), aerialking (05-02-2019, 04:12 PM), kevinjaye (04-13-2019, 03:44 AM), oloyeadeniran (04-16-2019, 11:38 AM), mart1nn (04-15-2019, 06:02 AM), nickydw (04-15-2019, 06:03 PM), Maniac_Powerwall (04-07-2019, 06:27 PM), jferrerd (05-09-2019, 07:28 PM), 3frain (03-21-2019, 12:10 AM), RikH (04-15-2019, 10:02 PM), BmoreThor (04-15-2019, 06:36 PM), richie241 (04-15-2019, 12:42 PM), singlecell (04-10-2019, 04:44 AM), Lekr (05-18-2019, 01:55 PM), Wardy (03-19-2019, 05:50 PM), camthecam (04-16-2019, 11:40 AM), Generic (04-15-2019, 01:42 PM), Solardad (04-13-2019, 09:57 PM), NMNeil (07-12-2019, 12:30 AM), stevelectric (04-13-2019, 06:27 PM), ma3006he (05-14-2019, 11:39 AM), Church1182 (03-20-2019, 03:08 PM), Mexx575 (10-14-2019, 05:19 PM), Dwain (04-13-2019, 07:46 PM), Dr mac (04-18-2019, 12:15 PM), Marrcin (04-19-2019, 01:54 PM), BitcoinBandit (04-23-2019, 11:30 AM), chewface (04-21-2019, 03:54 AM), kenzu (05-17-2019, 08:02 AM), A713083 (05-01-2019, 11:10 PM), doctorjkill (06-12-2019, 06:21 AM), meclait (04-14-2019, 08:14 AM), gigaz (04-17-2019, 11:03 AM), gpearce52 (05-07-2019, 11:39 PM), Lucan (05-10-2019, 11:03 PM), Codemonkey76 (04-14-2019, 12:36 PM), Rubert (06-08-2019, 01:45 PM), 100kwh-hunter (04-23-2019, 02:32 PM), Rossebaugh (03-19-2019, 01:53 PM), Invisionelite (03-24-2019, 01:30 PM), bairleafarm (04-02-2019, 12:50 AM), drbacke (06-12-2019, 06:13 PM), neill121 (10-12-2019, 08:10 AM), daromer (04-13-2019, 08:12 AM), Oz18650 (04-13-2019, 04:53 AM), Jason Morris (03-22-2019, 04:42 PM), Jejochen (10-01-2019, 05:55 PM), Drokz (05-17-2019, 08:26 PM), Headrc (03-19-2019, 02:13 PM), deGrootElectronicsRecycling (03-21-2019, 09:59 AM), Eratigena (03-19-2019, 08:44 PM), ToLiKomm (03-20-2019, 10:16 PM), Grumplestiltskin (05-15-2019, 07:32 AM), Ivo Staelens (09-04-2019, 05:55 PM), Geek (04-15-2019, 01:27 AM), Sean (04-13-2019, 11:40 AM), Korishan (03-19-2019, 01:11 PM), PAF (04-13-2019, 11:42 AM), wim (04-14-2019, 05:41 AM), watts-on (04-13-2019, 12:22 PM), Stefaan De Ridder (04-14-2019, 07:51 AM), BlueSwordM (05-07-2019, 11:44 PM), KaminoReal (03-21-2019, 08:50 PM), Crimp Daddy (03-19-2019, 09:41 PM), Redpacket (04-11-2019, 10:41 AM), Ibiza (04-11-2019, 07:58 AM), nkako (04-12-2019, 06:29 PM), neowolf (05-24-2019, 05:41 AM), yoeri_w (04-21-2019, 12:12 AM), MGPTWEGB (04-13-2019, 01:21 PM), WuggyBuggy (03-19-2019, 09:45 PM), emuland-metroman (03-26-2019, 11:26 AM), jaeger-audiodesign (04-14-2019, 03:56 PM), clupton (04-28-2019, 03:55 PM), Katarn_89 (04-23-2019, 10:15 PM), 100fuegos (04-14-2019, 09:59 PM), Riplash (04-12-2019, 09:57 PM), Onizuka (03-21-2019, 09:58 AM), Zvonko000 (10-10-2019, 01:37 PM), Jonas Vanbeveren (04-16-2019, 06:53 AM), davidtrn24 (04-16-2019, 01:53 PM), Oliman (04-23-2019, 06:33 AM), Cherry67 (04-10-2019, 08:56 AM), Sholphin02 (04-14-2019, 10:53 PM), Walde (04-14-2019, 04:02 PM), Leipi35 (04-10-2019, 04:54 PM)
