100kwh-hunter
Active member
- Joined
- Mar 2, 2019
- Messages
- 1,374
Hey guy's,
What defines a heater?
When i was charging some cells, i found that some of those cells where warm to the touch.
I put a mercury thermometer against them and it was reading (pending)between 38 and 42 degrees celsius.
They where charged with the tc4056a with a load that was a constand 900mah-1000mah.
When they where over 3.8v they where getting warm.
The cells in question are the cells in the picture, but it's only those one'sbelow in my hand, the one's at the topdoes not seem to generate so much heat.
This is also a reason for the picture, two same numbers but different looks??!?!?@?
From the same brand but ending on pf(2950ah) did not give so much heat....just like the one at the top.
(charged 250 of them pf's)
Funny thing: ALL of the one's belowin the pictureof my hand seems to have this problem.
Got almost 120 of them. 3 ebike battery's.
They are to old or to abused? Istill don't have an ir meter.
Thanks in advance
the psu is 30 amp 6 volt, not a aliexpress thingy.
Wire is 60 centimeters long and 4mm thick
Thanks in advance
