Hi guys,
would you please let me know the upper and lower thresholds you are using for charging voltage of your powerwall battery packs?
As far as I know, the upper boundary is 4.2 volts, but from what I understand, no one intentionally charges their powerwall battery packs to that level.
As far as the lower boundry, it seems to me that 3.42 volts would be the lowest level that could be used.
I'm assumingthat a24 volt inverter accessing a 7s batterywouldrequire a minimum voltage of 3.42volts (24/7), similarly a 48 volt inverter accessing a 14s battery would also require a minimum of3.42 volts (48/14).
thanks,
Paul
thanks,
Paul
