Fan Wiring
Hi All,
Just needed some advice on wiring of fans to cool the new Eddi i installed a week or two back.
Using a 4W, 12V solar Panel - jaycar.com.au/4-watt-12-volt-solar-panels-amorphous/p/ZM9026
Noctua NF B9 REDUX 92mm - noctua.at/en/nf-b9-redux-1600-pwm
Noctua NF R8 REDUX 80mm - noctua.at/en/nf-r8-redux-1800-pwm
My question is what is the best way to wire these fans to the solar panel?
I currently have them both tapping into the solar panel at the same spot (In parallel). If i power them on at the same time both fans spin. However if i let the sun slowly power them up e.g. from sunrise, Only the 80mm fan spins untill i cover the solar panel entirely, let the fans spin down and then power them up.
Should i wire them properly in parallel? or series?
If parallel which fan in the parallel chain first? (does it matter?)
So that solar panel has spec for voltage which are too high for the fans without a regulator.
The panels max power point (best volts/current to operate at) is 17.5V & 286mA (in perfect conditions when the panel is cold)
When the panel heats up in the sun after maybe 1/2 an hour it'll be a lot less output, maybe 70% of the above.
The fans are motorized devices that draw higher current to get them started & effectively "short out" the panel when the sun comes up gradually.
So the trick is to use a device/circuit called a maximizer that lets the panel get to about say 17V & gives the fans whatever current is available.
This will let the fans start much better.
Google this"solar maximizer circuit"
Eg here: https://www.ledsales.com.au/pdf/Maxi_max...ctions.pdf
But you also need 12V regulator in there because the fans are only rated 12V & 17V will blow them eventually.
A simple 12V regulator can be built with a transistor on a heatsink & a 12V zener & a resistor or two.
Eg here: http://www.learnabout-electronics.org/PSU/psu22.php
(04-13-2019, 12:50 AM)Redpacket Wrote: Snip
So are you saying in the morning when the sun is slowly coming up that it is affecting the fans?
I tried putting two fans of the exact same spec and they both wouldn't start as the sun slowly rose, however when i just turn them off/on they all started spinning.
Is there any way to fix this?
I just need a way to cause the circuit to reset which will triger them to both turn on.
Are you OK with simple electronics & soldering or prefer a modlue, eg ebay, jaycar, etc?
(04-14-2019, 09:51 AM)Redpacket Wrote: Are you OK with simple electronics & soldering or prefer a modlue, eg ebay, jaycar, etc?
Would prefer to just buy something.
Pretty much if I have two different size fans, the smaller second one spins with sunrise. If you reset, then both work.
If I have two fans same size, then both don't spin with sunrise unless you reconnect them.
Also appreciate all the help
You need bigger solar panel or smaller fans or a controller that start Them when enough Sun exist.
One thing - can you measure the voltage when 1 fan is spinning and the second attached ?
1 kWp in Test
Ultra low cost
(04-14-2019, 09:58 AM)daromer Wrote: You need bigger solar panel or smaller fans or a controller that start Them when enough Sun exist.
Tried that, I think it's something to do with the fans' control logic board that stops them after a while of having low voltage.
Any recommendations on a controller that would do that?
(04-14-2019, 10:07 AM)Cherry67 Wrote: One thing - can you measure the voltage when 1 fan is spinning and the second attached ?
Wish i could, don't own a voltmeter unfortunately...
But even when the sun is high and the panel is getting maximum solar, the same phenomenon happens. Either only one fan spins or both aren't spinning untill i disconnect and reconnect power.
After the inspiring comments of the others, i just assume the current of both fans to start required is more than the panel can deliver. There is a buck converter available which has an MPPT ( wich is an undervoltage shutof) in the Chinese market, i will add the link later. Perhaps this could work.
1 kWp in Test
Ultra low cost
This module is what you want:
https://www.ebay.com.au/itm/Lithium-Batt...3945740995
You'll need to buy a cheap multimeter to set the voltages.
Connect the solat panel to the Vin input.
Connect a fan to the "bat" output.
Get the panel in full sun.
Use the blue adjustment pots to set the MPPT voltage to about 17V & the V-out to 12V.
