Starting pack build
Hi guy I have just hit the 1000 good tested batteries so I have started ordering pack build bits.
I am building a 14s80p.
using cell holders
https://www.aliexpress.com/item/Onsale-10Pcs-4x5-Cell-Battery-Spacer-18650-Battery-Radiating-Shell-Pack-Plastic-Heat-Holder-Bracket/32838217795.htm
I am going to solder and have a good 80w weller iron and have done some practice on low capacity cells work fine i think.
ordered some fuse wire for neg side and 2amp glass fuses for positive side.
https://www.aliexpress.com/item/1-ROLL-Household-factory-insurance-lead-wire-Large-volume
https://www.aliexpress.com/item/1000pcs-...4c4dj4J1Iy
Not sure on the fuse wire it said 3a but diameter is .8mm i dont know if this might be to hard to work with.
I also ordered some shrink wrap in white to see what they look like
https://www.aliexpress.com/item/100-PCS-Li-ion-PVC-Heat-Shrink-Tubing
I am building the busbars with 2.5mm copper wire and lugs.
I have about 4 weeks to wait from aliexpress.
Thanks for reading.
