Safely housing the battery bank
CO² does only have a very limited cooling effect. It would not keep other cells from heating up.
(05-14-2019, 03:17 PM)5buBZMKeJZgapTGsbGzKf Wrote: CO² does only have a very limited cooling effect. It would not keep other cells from heating up.
Not the cooling effect (not that limited) but more the replacing of oxygen in the cabinet is what i am looking for...
i know a lithium fire needs no oxygen (has his own) but it might put out the burning plastic holders and stuff faster ... right?
If you can get it, halon gas.
That will replace oxygen very quick.
Easier to get: nitrogen.
But you will need to air tighten your cabinet.
(I am planning a experiment in a vacuum chamber, let see what happens)
The problem would be to apply it, maybe a motor on high rpm with a coil or something to pull the pin out that is attached to a wire?
Before a c02 extinguisher is empty it will blow his load in a minute, (6 kilo).
A Co2 cylinder must be shaken every year by holding it upside down again and again, to let the components stay mixed together, if not done every year the components will settle.
1500 waiting for testing.
3 chargers?
With best regards
That's not the problem.
To put out a lithium-ion fire, you need either sand or just regular water.
Why? Temperature control.
Since lithium ion compounds can combust, and provide their own goddamn oxygen, you need to remove heat from the reaction.
Reducing heat as much as possible is critical to prevent chemical reaction acceleration.
So, water or a sand trap to reduce heat should be used.
This is always why I have a small jar filled with water besides me when I teardown lithium ion packs, and during the summer, some sand. Smile
I've had one time when a nickel strip failed on me, and caught fire right before I cut them. Had to throw the cell in a buck of water, then sand.
Some powertool manufacturersuse strips so large that even a small twist will cause a short, and since nickel has high resistance, bad things can happen.
(05-15-2019, 06:29 AM)100kwh-hunter Wrote: If you can get it, halon gas.
Why are you suggesting the use of a banned substance on a DIY forum ?
While the production of Halon ceased on January 1, 1994, under the Clean Air Act, it is still legal to purchase and use recycled Halon and Halon fire extinguishers. In fact, the FAA continues to recommend Halon fire extinguishers for aircraft.
That being said Halon would not work anyway as it is a gas that replaces the O2 in the surrounding enclosure. It does not restrict the production of O2 which is what Li-ion batteries do. It is a fire than can only be smothered using a non conductive dry chemical.
Lithium-ion batteries are considered a Class B fire, so a standard ABC or BC dry chemical fire extinguisher should be used. Class B is the classification given to flammable liquids. Lithium-ion batteries contain liquid electrolytes that provide a conductive pathway, so the batteries receive a B fire classification.
Last count as of 8/7/2019
For Info Google Drive
There's only a very very limited number of legal uses of Halon these days, including crew compartments in aircraft, along with some space and military applivations - suggesting its use for our purposes is somewhat erroneous.
(05-20-2019, 01:01 PM)Sean Wrote: ....... - suggesting its use for our purposes is somewhat erroneous.
I totally agree Sean. As I said it would not work on a Li fire anyway.
But when it was legal it was pretty nice to have in the auto shop when a carburetor caught fire.
Poof out goes the fire and limited damage. But we don't have carburetors anymore so......
I didn't know that, it was just a thought, about halon, sorry.
1994, time flies.
So sand seems the option to go then to keep things simple.
In a plastic bag on top of the powerwall.
There are still persons who collect and drive old cars with carburetors, just saying.Smile
Just to start a 8.8 liter v8.......
3 chargers?
With best regards
For fire control..
If one cell goes "a wall" on a bad way, i was thinking to cover every cell hole in plaster or something.
But plaster need to be applied when wet, electra and moisture? or there brittle steel casings and moisture?
How about to cover each cell up with some foam or rockwool?, so when one cell goes puff, the other cells will be not damaged by the sparks?
Of course the "corck" must come off with ease.
I think one cell can not set something on fire, unless you have tinder wood/dry grass/paper nearby?
I have some time this weekend, lets see if i can make a test thingy...any ideas?
Best
Small supplemental about halon gas:
Its still legal around here, BUT you must have a permit for it, like owning gun powder.
They outlaw it from 2006/7, after 2010 you could have a permit for it, if there is a reason for ashore.
For offshore its a different story, they got other rules,
3 chargers?
With best regards
100 User(s) read this thread:
daromer (07-12-2019, 03:45 PM), Sean (08-10-2019, 04:38 PM), mike (05-20-2019, 06:33 PM), Korishan (08-09-2019, 10:50 PM), PAF (08-07-2019, 07:24 AM), Franky Beuselinck (05-08-2019, 12:36 PM), Mike C (04-20-2019, 12:08 AM), jdeadman (08-06-2019, 11:36 PM), wim (08-06-2019, 08:13 PM), rebelrider.mike (05-06-2019, 06:09 AM), watts-on (07-13-2019, 02:01 PM), Hanssing (08-13-2019, 06:20 AM), Stefaan De Ridder (05-15-2019, 05:30 PM), BlueSwordM (08-17-2019, 11:29 PM), Mazlem (08-09-2019, 02:23 AM), Geek (08-12-2019, 12:46 AM), Jon (07-14-2019, 10:31 PM), Ivo Staelens (08-13-2019, 09:46 AM), Swake (05-04-2019, 12:16 PM), ChrisD5710 (04-27-2019, 08:11 AM), Oz18650 (05-06-2019, 04:11 AM), bigblue (05-04-2019, 12:48 PM), Ste Collister (05-04-2019, 06:50 PM), Charly144 (04-22-2019, 07:01 PM), djuro (08-12-2019, 06:42 AM), maunz (05-30-2019, 11:17 PM), spinningmagnets (05-15-2019, 02:04 AM), jm1 (08-13-2019, 04:53 PM), drchips (04-20-2019, 12:58 AM), Issac (07-09-2019, 02:27 PM), Chablis_m (05-20-2019, 10:16 AM), Headrc (07-12-2019, 01:39 PM), kanchana (05-21-2019, 03:29 PM), rodagaster (05-04-2019, 02:17 AM), Crimp Daddy (06-17-2019, 04:48 PM), jonyjoe505 (05-03-2019, 06:15 PM), Redpacket (07-26-2019, 09:25 AM), velside (08-08-2019, 01:32 AM), completelycharged (08-10-2019, 01:44 PM), Ibiza (07-13-2019, 06:01 PM), Zvonko000 (08-06-2019, 08:27 PM), Jonas Vanbeveren (08-18-2019, 03:44 PM), davidtrn24 (04-20-2019, 03:40 AM), Oliman (07-13-2019, 01:53 AM), farmerjohn (04-29-2019, 04:12 PM), Bubba (08-10-2019, 02:00 AM), Leo_C (08-22-2019, 05:20 PM), Cherry67 (06-19-2019, 02:42 AM), Sholphin02 (05-15-2019, 12:20 AM), Walde (05-14-2019, 03:21 PM), crashintoty (06-23-2019, 07:29 PM), Riplash (08-10-2019, 06:47 PM), 100fuegos (05-05-2019, 02:30 PM), edd021 (04-22-2019, 01:59 AM), Jim Jr. (04-19-2019, 04:03 PM), Katarn_89 (07-14-2019, 04:06 PM), ungp (04-26-2019, 07:18 PM), w0067814 (05-15-2019, 01:15 PM), HikingGuy42 (05-15-2019, 03:04 PM), Gregor Scott (05-14-2019, 01:00 PM), Buzz0515 (04-26-2019, 06:00 PM), chuckp (08-06-2019, 09:13 PM), emuland-metroman (07-12-2019, 09:18 AM), hazSolar (04-24-2019, 03:01 PM), Truth (04-30-2019, 12:55 AM), jaeger-audiodesign (07-12-2019, 01:05 PM), clupton (08-21-2019, 03:56 PM), sl1me (07-20-2019, 06:09 AM), Shawndoe (05-05-2019, 07:45 AM), Wolf (08-07-2019, 01:45 AM), 5buBZMKeJZgapTGsbGzKf (08-07-2019, 05:38 PM), Lekr (05-24-2019, 05:01 PM), camthecam (06-21-2019, 12:12 PM), Generic (06-16-2019, 02:42 PM), rettore (05-20-2019, 12:16 PM), Solardad (05-15-2019, 05:28 PM), Speicher (08-10-2019, 01:48 PM), stevelectric (08-09-2019, 01:37 PM), richie241 (05-20-2019, 02:21 PM), eric.peton@laposte.net (05-26-2019, 12:23 AM), ajw22 (08-10-2019, 01:32 AM), RikH (08-06-2019, 08:43 PM), oloyeadeniran (08-25-2019, 11:42 PM), mart1nn (05-21-2019, 08:35 AM), OffGridInTheCity (08-10-2019, 12:29 AM), jferrerd (05-09-2019, 09:41 PM), chamele0n (04-20-2019, 07:48 AM), Powersaver (06-19-2019, 12:53 PM), Tobeabrepper (05-20-2019, 03:27 PM), Richard (04-28-2019, 06:42 AM), bertvaneyken (04-27-2019, 06:04 PM), Overmind (05-03-2019, 12:01 PM), ma3006he (06-17-2019, 01:21 PM), rhedbatt (05-09-2019, 06:37 AM), strat24v (05-29-2019, 07:27 AM), Omalik (08-14-2019, 09:50 PM), Rubert (07-13-2019, 03:27 AM), 100kwh-hunter (08-29-2019, 09:43 AM), Lexi (05-02-2019, 08:25 PM), juanjo57 (06-17-2019, 08:04 AM)
