Powerwall demo
Hello Smile
Thats my little "powerfloor" created for fun and some education Big Grin
I decide to use a repack ICR18650-26F cells (112pcs) + ICR18650-26H (28pcs) in 7s20p
Charge controler is a Tracer 1210AN working with one 195Wp mono solar panel
230V inventer is a cheap 300W solution for truck 24V systems
Cables have a 6mm2, for balancing I order a 1s deligreen solution
Today is its first day of working Smile
Best regards Marcin Smile
Redpacket likes this post
little update Wink
I was add 28 cels to my packs
ICR18650-26H - 7pcs
LGDAS31865 - 21pcs
and also I have some laptop batterys Big Grin
rewraping LG's
growing Rolleyes
Looks good. Keep posting updates!
Parcel arrived Big Grin
Another Tracer - 1206AN with temp. sensor
Today start working with my 2x 10W in series, very old china panels Big Grin
I planing to buy another solar panels and set it:
1210AN with 1x 330W panel
1206AN with 2x 195W panels in parallel
Meanwhile I finish capacity testing some laptop cels, now i'll give them some weeks to check self discharging
Best regards Wink
Marcin
RikH likes this post
Hej Marcin Smile
Great job, how's the outcome and capacity ?
What did you use for fusing ?
Packs build:
7S1P 60Ah ~1.5kW SAMSUNG SDI prismatic cells - I'm looking for more info about them / PV if you know more Huh
7S84P 240Ah ~6.2kW from 588x cells LG MG1 2850mAh
Inverter - 3kW AIMS  pure sine
Solar - considering addding 220W with MPPT Make Sky Blue 30A
Set up for mobile gastronomy 2kW cooling compressor + 500W appliancies
Spot Welder - Mactronic V3.
(06-26-2019, 02:13 PM)Issac Wrote: Hej Marcin Smile
Hey, sorry for late reply, now its something about 2,7 kWh
For fusing I use Eaton DC breakers, ANL fuse on battery, Schneider B10 at AC site
update  Big Grin
added repacked 77pcs. INR18650-29E and 35 LGDAS31865, now its 7S40P with ~2,7 kWh
added some breakers, bus bar and metal case
I waiting for DC breakers for PV cables
Battery cable is 25mm^2
Bus bars made from copper 20x10mm with holes for M8 screws
Batteries are on brown ceramic
I also was change solar panels for 2x 195W + 1x 315W
Best regards [Image: wink.png]
Marcin
Looks nice - congratulations - Its so much fun at the stage where things start working!
Marrcin likes this post
In addition to the balancer, you need to add some sort of BMS to stop charge/discharge automatically when any one pack gets too high/low. It only takes a quick distraction at the wrong time to ruin the batteries by discharging too much, or a fire by charging too much.
Marrcin and OffGridInTheCity like this post
Modular PowerShelf using 3D printed packs.  30kWh and growing.
(08-31-2019, 10:47 PM)ajw22 Wrote: In addition to the balancer, you need to add some sort of BMS to stop charge/discharge automatically when any one pack gets too high/low.  It only takes a quick distraction at the wrong time to ruin the batteries by discharging too much, or a fire by charging too much.
You right, can somebody recommend something cheaper than batrium system?
At the moment you have just a 300W inverter.
Say at peak it uses 600W
When the batteries are near empty, you have a system voltage of just 21V.
So the worst case current draw is 600W/21V ~= 29A
For charging, it should be around 525W / 21V ~= 25A
I think something like the following would be a reasonable start. I'd go with the 60A version. It not much more expensive, you get more safety headroom, and you get the option of using a higher wattage inverter in the future. You may need the USB/PC adapter to configure more advanced parameters.
https://www.aliexpress.com/item/32840764...574acdncWu
https://secondlifestorage.com/t-Good-Chinese-BMS-review
PS. not affiliated, but I use 3x of those 14s60A types (@30A max) in my powerwall. Very happy with them.
100 User(s) read this thread:
hbpowerwall (09-18-2019, 03:14 AM), daromer (08-31-2019, 08:23 PM), Sean (08-31-2019, 11:24 PM), Majorphill (09-02-2019, 06:27 AM), Korishan (09-01-2019, 07:30 PM), PAF (09-01-2019, 11:55 AM), Franky Beuselinck (09-06-2019, 08:36 AM), Mike C (04-20-2019, 12:26 AM), jdeadman (09-03-2019, 03:32 AM), 2146 (05-08-2019, 02:37 PM), wim (09-01-2019, 02:39 PM), watts-on (06-27-2019, 01:03 PM), Hanssing (06-28-2019, 06:49 PM), Stefaan De Ridder (06-26-2019, 02:19 PM), KaminoReal (04-29-2019, 07:05 PM), Mazlem (09-10-2019, 06:01 PM), Geek (09-02-2019, 03:56 AM), Ivo Staelens (09-01-2019, 01:21 PM), Grumplestiltskin (06-28-2019, 07:24 AM), ChrisD5710 (05-01-2019, 07:48 PM), cristof (04-24-2019, 09:15 PM), Oz18650 (09-01-2019, 12:20 PM), bigblue (04-26-2019, 11:01 AM), Charly144 (05-07-2019, 09:00 AM), djuro (08-31-2019, 05:51 PM), sturgeo (09-05-2019, 07:08 AM), Drokz (09-01-2019, 07:57 PM), Issac (07-22-2019, 01:54 PM), mbrunton (04-20-2019, 09:35 AM), rogales141 (07-06-2019, 01:45 PM), ARLISS (08-31-2019, 08:52 PM), Crimp Daddy (04-19-2019, 07:37 PM), Redpacket (09-01-2019, 04:28 AM), Ibiza (09-01-2019, 05:41 PM), Krokodino (05-10-2019, 02:21 PM), Christian Schneider (04-24-2019, 03:35 PM), Onizuka (06-27-2019, 10:24 AM), Zvonko000 (05-01-2019, 07:59 PM), Oliman (04-29-2019, 11:28 PM), Peter T (04-19-2019, 07:05 PM), choncy12 (09-01-2019, 12:14 AM), Wobbleszo (04-29-2019, 04:42 PM), JDish (05-02-2019, 09:47 AM), Cherry67 (07-03-2019, 11:14 AM), Sholphin02 (09-03-2019, 02:38 AM), Walde (09-01-2019, 08:56 AM), Riplash (09-02-2019, 03:23 PM), 100fuegos (06-26-2019, 08:26 PM), Jim Jr. (09-02-2019, 01:15 PM), mishok (05-02-2019, 02:30 PM), Katarn_89 (04-29-2019, 03:46 AM), ungp (04-25-2019, 08:39 PM), w0067814 (04-21-2019, 05:27 PM), nweibel (09-05-2019, 10:56 PM), michaell (07-07-2019, 02:24 PM), gguillou (09-01-2019, 11:42 PM), neowolf (09-01-2019, 12:27 PM), yoeri_w (04-21-2019, 12:06 AM), chuckp (09-01-2019, 07:57 PM), photon4 (06-27-2019, 02:38 AM), grumble (09-01-2019, 01:00 PM), WuggyBuggy (06-26-2019, 04:31 PM), emuland-metroman (05-06-2019, 07:22 AM), Robrecht (09-01-2019, 04:59 PM), Beholder (04-20-2019, 05:25 PM), jaeger-audiodesign (09-04-2019, 05:08 PM), clupton (09-05-2019, 04:21 AM), Leipi35 (05-04-2019, 08:12 AM), singlecell (04-20-2019, 10:51 AM), Wolf (09-01-2019, 05:16 PM), Lekr (09-09-2019, 06:59 PM), camthecam (09-04-2019, 11:39 PM), Generic (04-20-2019, 03:29 AM), rettore (09-02-2019, 04:24 PM), Solardad (09-01-2019, 11:40 PM), stevelectric (06-26-2019, 03:21 PM), richie241 (05-14-2019, 12:40 PM), ajw22 (09-01-2019, 08:52 PM), BmoreThor (05-02-2019, 01:18 AM), RikH (09-05-2019, 08:24 PM), newone972 (07-23-2019, 10:19 AM), DomingoRP (07-08-2019, 05:08 PM), Lagachette (09-04-2019, 01:30 PM), oloyeadeniran (06-27-2019, 10:29 PM), mart1nn (09-02-2019, 09:11 AM), OffGridInTheCity (09-01-2019, 01:35 AM), jferrerd (05-01-2019, 08:06 PM), chamele0n (Yesterday, 07:13 PM), Rhoos (09-18-2019, 03:25 AM), sparkgap (05-26-2019, 06:43 PM), Powersaver (04-29-2019, 01:58 PM), Richard (09-01-2019, 07:02 PM), bertvaneyken (04-19-2019, 09:44 PM), ma3006he (09-14-2019, 11:24 AM), beserker786 (04-25-2019, 03:02 PM), winny (09-12-2019, 02:24 PM), Lucan (05-08-2019, 02:40 PM), strat24v (04-25-2019, 05:41 PM), BarryG (06-27-2019, 05:51 PM), Rubert (06-28-2019, 03:57 PM)
