Hi,
Thanks in advance for helping this Croatin Adriaticnoob
I have two same outboard trolling motors for my sail boat,TROLLING MOTOR 120Lbs, Viamare 1470W-24V, here's the link:
https://www.parsun.si/en/product/el...otor-za-coln-120lbs-viamare-1470w-24v-3600kg/
Planning to buy these batteries,Panasonic NCR18650PF 2900mAh - 10A,
https://eu.nkon.nl/rechargeable/18650-size/panasonic-ncr18650pf-3-7v-2900mah.html
I just boughtSunkko 709a spot welder, and I'm learning about copper busbars and nickel strips and fuse wires... a bit confused which way to go
Since the motor draws max 61Amps I'm thinking on making one pack 7s56p for powering the motor, is that a good idea?
Can that pack power both motors in the same time?
Thank You,
Igor
Thank You,
Igor
