18650 cell voltage 6.4V
Hi
I am ripping my first batch of laptop batteries and have come across a few anomalies.
A fully working laptop battery Dell FV993 11.1V 97WH with 9x 18650 model Samsung ICR18650-30B and all cells are testing at 6.04-6.45V each.
I thought that my Voltmeter may be faulty so I tested a rechargeable 1.5V AAA battery and that returned 1.7V. Also opened another laptop battery and tested the cells - all around 3.4V
The third battery pack with 3 cells Samsung ICR18650-30B also 1st cell 1.82V and the remaining two 5.46V and 5.48V
Is Voltage above 4.2 possible for 18650 and what should I do about the 5V+ ones?
Thanks
overcharged
(04-24-2019, 09:51 AM)emuland-metroman Wrote: overcharged
Is that terminal or can the cells be recovered?
Are you measuring across the terminals of a single 18650, after it's been dismantled from the pack ?
Measuring a single cell after being removed from the pack.
Certainly overcharged, you'll know what affect that's had on its capacity after you've fully tested it.
I have almost never seen cells being at above 4.5V... I would like to see an image of you checking the terminal and also how you crosscheck the voltmeter against another proper source.
A voltmeter with faulty battery generally give very very weird results!
Cells at 6V.. Doubt that but il take it back if its true Smile
dwarflundgren, 100kwh-hunter, ajw22 And 3 others like this post
Thumbs Up
(04-24-2019, 01:37 PM)daromer Wrote: I have almost never seen cells being at above 4.5V... I would like to see an image of you checking the terminal and also how you crosscheck the voltmeter against another proper source.
That was a great call - thank you!
I changed the battery of the voltmeter and the 6.5V cells now read 4.15. Big Grin
ajw22 likes this post
This is why I own more than 1 volt meter lol... if everyone agrees with each other, you know you're in business.
chuckp likes this post
Faulty battery is Common Smile
Yeah i have more than 1 voltmeter to because of this Smile
