andreiluis
New member
- Joined
- Apr 26, 2019
- Messages
- 6
100kwh-hunter said:looks like sanyo ur18650a or ur18650fm
Look for some embedded numbers on the wrap itself, its not printed on it.
Its very hard to see, use some good light on it
Best
not2bme said:Look harder, it will not be printed in ink, but stamped or embossed into the wrapper. Also look under Sanyo in our cell database (https://secondlifestorage.com/celldatabase.php). Sanyos usually have a purple (or some colorful ring) on the positive terminal.
@andreiluisandreiluis said:In fact, the term M06A is embossed into the wrapper. I looked again and again, I cannot find any other caracters on this cell. But, looking the cell database, I found one important info, these cells here, has a Blue Insulator Ring, so I'm pretty convinced that they are NCR18650GA cells.
Thanks for the help.
Wolf said:@andreiluisandreiluis said:In fact, the term M06A is embossed into the wrapper. I looked again and again, I cannot find any other caracters on this cell. But, looking the cell database, I found one important info, these cells here, has a Blue Insulator Ring, so I'm pretty convinced that they are NCR18650GA cells.
If these cell came out of a Dell laptop then that must be some kind of battery. The NCR18650GA 3300mAh is a Sanyo High capacity high drain battery more likely to be found in a power tool not a laptop. Same with a UR18650RX 1950mAh high drain.
I would venture to guess that it is a SanyoUR18650F 2500mAh or aUR18650WX 1500mAh (although I haven't seen any of those). The insulator is more of a cyan coloron those ratherthan a sky bluethey are not easy to tell apart. I have pulled many of them out of laptops esp Dell.
Also if you have a proper IR checker(4 wire kelvin 1kHz AC m? tester) you can tell right awayas the IR of high drain 18650s is usually in the <25m? range. The standard battery (UR18650F) which I am assuming you have will have an IR in the >45m? range.
I could be wrong but if it came out of Dell laptop battery .......................
andreiluis said:Thanks for your answer Wolf. After your message I took a look at the cell database and the batteries I have here. You're probally right. I was comparing the insulator ring ofUR18650F and UR18650WX, and the insulator ring blue of UR18650F appears to me to be a little "soft" than the blue of UR18650WX, is that it? (That is correct)Comparing these photos, and my cell, I guess I have UR18650F cells.
Unfortunately, I don't have a IR tester, all I have is a digital multimeter. In my office I have the plastic of the Dell battery I dissasembled to get these cells, by the battery specifications, can't I get a clue what is the capacity of these cells?
Wolf said:andreiluis said:Thanks for your answer Wolf. After your message I took a look at the cell database and the batteries I have here. You're probally right. I was comparing the insulator ring ofUR18650F and UR18650WX, and the insulator ring blue of UR18650F appears to me to be a little "soft" than the blue of UR18650WX, is that it? (That is correct)Comparing these photos, and my cell, I guess I have UR18650F cells.
You can get a clue as to what the batteries in a pack will produce.
As you know amperage adds up in parallel and voltage stays the same.
the UR18650F is a 2500mAh battery so 2 in parallel would be 5000mAh and 3 would be 7500mAh
In this picture you have a 3 series3 parallel pack with 6600mAh rating (66003=2200) so you would expect for this pack to have 9 2200mAh cells.
This pack is 3s2p with 4910mAh (49102=2455) so this pack would haveeither 6 2400mAh or 6 2500mAh cells (sometimes they fudge the numbers a bit) but close enough.
You can determine the packs number of series cells by voltage 18650s are nomaly 3.8V so 3.8X3=11.4 and 3.8X4=15.2 take the Voltage with a grain of salt also but are close enough.
