Silly question about 3kw solar, charger and battery
The simplest way would be to have a regular mains powered battery charger switched when your solar input is high.
A typical grid tied solar panel installation usually runs high voltage DC (200-400V ish) & you don't want to mess with that.
If you already have a grid tied setup, like the OP, you want to build an AC coupled system with a hybrid inverter like the Victron mentioned previously. If you look up those systems, they go between your current inverter and the panel/grid and either let it feed your house, charge batteries, or sell to the grid.
(05-02-2019, 12:46 PM)hazSolar Wrote: .....  they go between your current inverter and the panel/grid and either let it feed your house, charge batteries, or sell to the grid.
Victron inverter/chargers are installed parallel to the existing grid tied installation not "between".
Very stupid maybe.
Disconnect your array and connect it directly to a vectron unit?
1500 waiting for testing.
3 chargers?
With best regards
(06-03-2019, 05:28 PM)100kwh-hunter Wrote: Very stupid maybe.
The problem with this from my experience is City Inspection.  By going off-grid I was able to legally bypass all the Power Company (not so good) requirements.   IF you hook victron directly (rather than parallel) I would imagine you would need to revisit Power Company requirements/permits. Maybe by doing parallel - you could avoid that.
P.S. I liked the question Smile
Same problem over here, and worse.
Despite power company requirements/permits
You are not allowed to go offgrid, they want to control.
You must deliver to them, battery's in large numbers is not allowed anymore(agm, lead acid ect) 2 max.
Try to get a tesla home battery.....ect ect
You must use something.
So built it of slowly...so i will only have a electric cooking plate/furnas on the grid Smile
3 chargers?
With best regards
70 User(s) read this thread:
skyricho (08-20-2019, 11:51 AM), Overmind (06-13-2019, 05:52 AM), Richard (07-06-2019, 12:28 PM), Powersaver (08-05-2019, 03:09 PM), OffGridInTheCity (06-05-2019, 02:22 PM), oloyeadeniran (06-07-2019, 02:50 PM), RikH (06-07-2019, 01:08 AM), ajw22 (06-06-2019, 12:04 PM), stevelectric (06-03-2019, 08:21 PM), Solardad (06-06-2019, 12:50 AM), Solalar (04-29-2019, 04:41 PM), Generic (06-04-2019, 03:55 AM), camthecam (06-11-2019, 06:29 AM), Wolf (06-05-2019, 01:53 PM), cowpen (06-16-2019, 11:11 PM), Leipi35 (06-05-2019, 03:33 PM), fleming (04-28-2019, 06:56 PM), VOLTRON78 (05-01-2019, 01:18 AM), 100kwh-hunter (06-06-2019, 06:30 PM), Cobra_Phil (09-02-2019, 01:48 AM), aminet (07-16-2019, 12:28 AM), Mlr112 (06-26-2019, 10:13 AM), Bobthebuilder (06-28-2019, 10:58 AM), Bruce43 (07-06-2019, 06:23 AM), Gizmosis350k (06-18-2019, 12:29 AM), Daverave54 (06-12-2019, 06:55 PM), tschmidt82 (06-05-2019, 06:28 PM), saddizdd7 (05-17-2019, 07:15 PM), Jacob89 (05-18-2019, 01:36 AM), TroyD (06-24-2019, 05:20 AM), Hasekura (04-28-2019, 06:02 PM), foamovercast (06-03-2019, 07:08 PM), Marrcin (04-28-2019, 03:53 PM), ben teker (05-13-2019, 08:06 PM), Truth (04-30-2019, 01:21 AM), Klug (07-01-2019, 03:16 PM), BaronVonChickenPants (06-06-2019, 12:38 AM), djuro (06-23-2019, 08:14 AM), Oz18650 (06-10-2019, 06:37 AM), ChrisD5710 (05-03-2019, 11:08 AM), Geek (06-11-2019, 05:33 AM), Chiptosser (05-06-2019, 12:43 AM), Stefaan De Ridder (05-02-2019, 02:24 PM), watts-on (06-06-2019, 08:14 AM), wim (06-03-2019, 08:10 PM), jdeadman (06-05-2019, 06:09 PM), PAF (06-06-2019, 10:54 AM), Korishan (06-05-2019, 10:05 PM), mike (06-05-2019, 02:28 PM), Sean (06-05-2019, 04:28 PM), daromer (06-05-2019, 02:56 PM), Chablis_m (06-05-2019, 05:02 PM), rodagaster (06-06-2019, 11:36 AM), jonyjoe505 (04-30-2019, 05:24 AM), hazSolar (05-02-2019, 12:46 PM), emuland-metroman (04-28-2019, 03:52 PM), chuckp (04-29-2019, 01:18 PM), w0067814 (05-02-2019, 09:34 PM), xephonics (05-24-2019, 11:06 AM), Katarn_89 (06-11-2019, 05:44 PM), Jim Jr. (04-28-2019, 12:58 PM), 100fuegos (06-05-2019, 09:10 PM), Riplash (05-03-2019, 04:20 AM), Cherry67 (04-28-2019, 07:07 PM), Bubba (06-05-2019, 09:35 PM), avm131 (07-05-2019, 11:21 PM), Oliman (05-15-2019, 08:46 AM), Zvonko000 (04-28-2019, 06:52 PM), Redpacket (06-04-2019, 03:18 AM), Chickey (04-29-2019, 11:41 AM)
