thunderheart
- Apr 4, 2018
- 276
Panasonic NCR18650BD is a mid-drain high capacity Li-ion cell in traditional 18650 format. It's rated at 3180mAh and supports discharging at up to 10A.
The battery was bought from my reliable supplier (Queen Battery) and tested withZKETECH EBC-A20and a self-made battery holder. It's a PC-connected battery tester supporting 4-wire measuring and discharging at up to 20A.
I've followed all the prescriptions of theIEC61960-2003standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 23.0-24.5C. To be sure in results i've done each testminimum twice(usually 3-4 times).
My cell has the following marking: C CV 7321.
Specifications from NCR18650BDdatasheet:
Rated capacity:2980mAh at 20C
Minimum capacity:3030mAh at 25C
Typical capacity:3180mAh at 25C
Nominal voltage:3.6V
Standard charge current:0.909A (0.3C)
Max charge current:1.5A
Charge end voltage:4.20V
Charge cut-off current:60.6mA (0.02C) (100mA used)
Max continuous discharge current:10A
Discharge cut-off voltage:2.5V
AC impedance at 1KHz:?35m?
Max weight:49.5g
The measured weight of my cell is 46.66g. Measured DCIR at 3030mAh was 23.81.0m? (in fully charged condition).
NCR18650BD capacity test results:
At 0.2C or 0.61A NCR18650BD's capacity was a bit higher than declared and it didn't go below 3020mAh all the way up to 10A. The curves look excellent even at 10A. Just a great cell, nothing to add.
Here is the video version of this review
Check outmyYouTube channelfor batteries, chargers and other stuff reviews.
I've launchedmy blogwhere you can find all my reviews in one place. Every new test/review will be first published on YouTube and in the blog. I'll be happy to see new subscribers, comments, suggestions and just your thoughts.
Max weight:49.5g
