100kwh-hunter
Active member
- Joined
- Mar 2, 2019
- Messages
- 1,374
Hi,
I bought several months ago a batrium bms for a 24v system with 14 longmons.
Now i have done some reading on this million dollar siteand its better for me to go to a 48v system instead a 24v system.
Can i use the bms that i already have?
I was not able to get the required info on there site, that why this question.
An other question:
Sinds i am planning to make 14 packs (48v) of 100 cells each(times 3(3x14 packs) for now to start with)
The first 28 packs will be at the same capacity.(2x 14 packs)
The first 14 packs will have a SOH of more then 90%
The second 14 packs between 80% and 90%, majority will be above 90%
The rest above 80%
After this only the same capacity per packand above 80% per 14 packs
I am going to use Daromer method to fill in the packs: start with the biggest pile of cells and distribute them over the packs, till that one runs out i will take a lower mAh bucket.
With this data as described as above, do i need a bms?
Question one: Can i use the bms that i already have?
Question two: Do i need a bms?
Any input or info is very appreciated, thanks in advance.
An other question:
The rest above 80%
