Is SUNKKO 709AD still the gold standard?
A colleague of mine wants to get into battery building as a business.
Is the SUNKKO 709AD in 220v still the best machine out there for production use in the USA or is there better?
I have a Sunkko 709AD. The welder does do a half decent job for most thing, thickness of the welding matetial will be the limitation "《.2mm". As a manufacturing tool, I think you need to look at something else or have multiple units. Since building my home battery bank with 0.18mm matrerial on the GND side an welding 3 spots per cell on 4+6 pulses the handle heats up to a temperature too hot to hold in your hand after 40 battery connection " 120 weld points". Welding fuses to positive side works ok and heat on the handle bearable. I've purchased a second handle to swap over when it gets too hot.
I do like the functionality of the unit to control the pulses and current and parts are available online from multiple suppliers.
aerialking likes this post
As a business no. You need to pay 2000-3000USD or more for getting a unit for such application.
Ibiza, BlueSwordM, aerialking like this post
These aren't really suited for business applications.
As a business, if you can afford a copper spotwelder, that would make your job better and cheaper over the long run.
