Question regarding Magnum Energy ME-ARTR
Hello, I am just starting to setup my off grid system, and I have been cutting my battery bank on and off every time I go to the property. I have noticed that I have to set the date and time every time on the Magnum Energy ME-ARTR (the advanced router).
Is this normal, or is there a way to save the settings I am missing? Also, if it is losing the date/time, is it also losing my battery settings?
EDIT: After reading the manual a bit more I found that the clock settings reset when it is powered down. So it is normal, and I should not have worried lol. Another example of "RTFM".
System: Magnum MS4448PAE, MPDH175-30D Panel, Magnum PT-100 Charge Controller, 14s15p 21.5kwh Lithium NMC battery bank, Batrium Watchmon 4, 16 Silfab SLA-M 310 solar panels.
What encouraged you to buy a Magnum, and a BMS that cant natively communicate ?
Me buying the inverter/charger setup before i decided on a BMS solution.
Then the BMS seemed easier to work with than other DIY setups.
If I was to do it again I would probably look for a more compatible pairing.
Sean likes this post
