Charging to 4.3v
Hey team,
I have just purchased some charger units for a bit of an experiment and turns out they use a USB plug in and give a 'full' charge as indicated by a green LED.
I then threw them in the opus once charged and they came up with a voltage of 4.3v on each cell!
What are peoples thoughts on that level of voltage? As I understand 4.2 is full and 4.3 is getting dangerous?
(05-31-2019, 10:20 PM)Scottietheyoung Wrote: Hey team,
Most cell manufactures have a 4.2 ±0.05 V spec on their cells. Also some cells actually go as high as 4.35V.
If the cell gets to 4.25 and the Opus decides to round up that would be your answer. Also the OPUS as a voltmeter Huh  Im not sure I would trust it that close. Best would be to check the voltage with a minimum of a 3 decimal place DVM or better yet with a 4. Big Grin
hbpowerwall and Korishan like this post
Last count as of 8/7/2019
For Info Google Drive
Life shortening if done regularly.
Some cells can take 4.3(5), most probably won't like it but not dangerous.
4.1 = full is the target for longer term power wall use, for capacity testing you're trying to follow the manufacturers specs hence 4.2V
+1, find a voltmeter you trust!
Take the unit apart and see if there's a switch inside to change from normal cells to HV (high voltage) cells. Maybe it's default setting is HV instead. But, I doubt this is the case. Even the Opus has 2 charge levels, but it's 4.2 and 3.7 (for LiFePO4 cells).
It's also possible you have a bad charger, even if new.
I'm in the process of bringing all mine down to 4v top voltage to try make them last as long as possible. but like wolf said, trust neither for a true reading
If you'd like to support the forum please feel free to use my affiliate links to purchase all kinds of stuff for your projects
Amazon - https://amzn.to/2qURmH2
eBay - https://goo.gl/6mrQHH
Aliexpress - http://s.click.aliexpress.com/e/bNLW537E
Banggood -  https://goo.gl/FF2v6W
Battery Hookup - http://bit.ly/2Oe9PLW
(05-31-2019, 11:58 PM)Korishan Wrote: Take the unit apart and see if there's a switch inside to change from normal cells to HV (high voltage) cells. Maybe it's default setting is HV instead. But, I doubt this is the case. Even the Opus has 2 charge levels, but it's 4.2 and 3.7 (for LiFePO4 cells).
possible but that looks like another cheap and nasty charger i had.
i knew it was crap when i got it for $5 at the flea new in box.
it had no real cc or cv modes and while testing it shorted placing full 5v across that slot.
that could lead to a nasty surprise.
the sliders were so crappy it wasnt even worth re-purposing as a universal holder.
(05-31-2019, 10:20 PM)Scottietheyoung Wrote: I have just purchased some charger units
Don't buy unknown shit. Take reliable chargers like Miboxer ones
My review of 4-slot Miboxer C4-12
Voltage and current accuracy check:
[Image: 3b2606.jpg]
Thanks team, they were super cheap and definitely nasty. As I said it was a bit of an experiment for me to see what you could get for that pitiful amount of money. The internals were appalling when I opened it up. Will bin and build charging board.
real voltage should be 4,25(0,05v off by opus)
Building Lifepo4 Powerwall - atm 1400 cells growing
I have 6 of them. All of them overcharge to between4.23-4.28 V. I bought a tube of TP4056 with the plan of replacing the ICs in them, but the pinout is different so it’s not based on that. Been thinking about etching a new PCB for it but I would need to desolder and move the “hooks” for the springs.
Nope. Unbranded IC/scraped the letters off them. Termination voltage seems internally set by bandgap reference, or in this case badgap reference.
No. cells
Indexed: 53
Processed ok, not yet indexed: ~3200
Broken down, untested: ~0
Not yet broken down: ~200 kg
65 User(s) read this thread:
Kna (09-13-2019, 09:17 AM), Richard (06-02-2019, 09:17 PM), OffGridInTheCity (06-02-2019, 11:19 PM), oloyeadeniran (06-12-2019, 11:01 AM), BmoreThor (06-02-2019, 02:20 AM), ajw22 (06-03-2019, 03:25 AM), stevelectric (06-01-2019, 05:30 AM), Solardad (07-09-2019, 01:08 AM), Generic (06-05-2019, 02:05 AM), Scottietheyoung (06-03-2019, 08:57 AM), Lekr (06-01-2019, 10:36 AM), Bastler_Ro (06-02-2019, 07:15 PM), Wolf (06-02-2019, 11:18 PM), Shawndoe (06-01-2019, 05:50 PM), clupton (06-01-2019, 04:52 AM), Overmind (06-04-2019, 11:31 AM), winny (06-03-2019, 05:52 AM), Magnum164 (08-10-2019, 04:50 AM), TheStigVVL (07-27-2019, 10:25 AM), pir8don (08-09-2019, 11:20 PM), Androfire (07-10-2019, 02:39 PM), Smackman (06-18-2019, 12:38 PM), Pantherman (06-11-2019, 10:17 PM), xahmedxsa (06-15-2019, 05:09 PM), billvon (06-02-2019, 02:50 AM), Kenjirou (05-31-2019, 11:45 PM), kc8adu (06-01-2019, 12:26 PM), dalibor.kozak@post.cz (06-19-2019, 07:06 AM), lange5766 (06-01-2019, 09:44 PM), EV Works (06-03-2019, 08:17 PM), 100kwh-hunter (06-01-2019, 01:30 PM), emuland-metroman (06-02-2019, 07:33 PM), chuckp (06-02-2019, 10:34 PM), Katarn_89 (06-04-2019, 03:09 AM), Geek (06-03-2019, 04:50 AM), BlueSwordM (06-01-2019, 12:15 AM), Chiptosser (06-01-2019, 11:55 AM), Stefaan De Ridder (06-01-2019, 01:20 PM), jesusangel (06-02-2019, 08:18 PM), watts-on (06-03-2019, 09:09 AM), wim (06-01-2019, 06:09 AM), jdeadman (06-01-2019, 12:49 AM), PAF (06-03-2019, 07:16 AM), A + A (06-02-2019, 11:15 PM), Korishan (06-03-2019, 12:22 AM), mike (06-02-2019, 10:40 PM), Sean (06-02-2019, 08:49 PM), daromer (06-02-2019, 05:18 AM), ChrisD5710 (06-01-2019, 08:19 AM), Oz18650 (06-02-2019, 01:14 AM), Jim Jr. (06-01-2019, 01:04 PM), 100fuegos (06-02-2019, 01:19 PM), Riplash (06-02-2019, 12:17 AM), Cherry67 (06-07-2019, 05:09 PM), Bubba (06-03-2019, 10:05 PM), thunderheart (06-13-2019, 09:00 AM), Zvonko000 (06-01-2019, 08:08 AM), Ibiza (06-03-2019, 10:39 AM), Redpacket (06-02-2019, 11:51 PM), jonyjoe505 (06-01-2019, 09:30 PM), Chablis_m (06-02-2019, 03:53 AM), drchips (06-02-2019, 10:56 PM), spinningmagnets (06-02-2019, 04:43 PM), djuro (06-01-2019, 03:22 PM), hbpowerwall (06-01-2019, 12:20 AM)
