Excel based RePackr
Hi All,
I've noticed a few people talking about the difficulty using Repackr with large amounts of cells, so I put together an excel based version that you can download at my google drive here:
https://drive.google.com/drive/folders/1...sp=sharing
This was a scratch-build so it may not handle available cells the same way as the real Repackr (because I don't know how it works), but it will balance very closely.  I have also added the ability to set a target mAh for each pack for those of you looking to expand your walls, but wanting to match your existing packs.  Lastly, if you put in your cell IR information it will calculate the pack IR and give you the total IR of the build.
Thanks to Wolf for sharing your Database and reviewing functionality as the build progressed!
Stefanseiner, Wolf, cadric like this post
Mobilis in Mobili
Cell count as of 10/10/2019
191 Cells of Everything Else
68 In progress
More info on my Google Drive
That Nemo is a work of art.
Big Grin Big Grin Big Grin
Nemo likes this post
Does not work in OpenOffice, LibreOffice or GoogleSheets. Wont run macros.
(06-08-2019, 05:56 PM)Herbi Wrote: Does not work in OpenOffice, LibreOffice or GoogleSheets. Wont run macros.
No it does not hence it is called an Excel based RePackr.
Mabe there are some OO, LO, or GS gurus out there that can modify those versions to work.
Stefanseiner likes this post
Yeah, unfortunately it does require running Microsoft Office.  As Wolf said if there's anyone out there that can transfer it to other platforms have at it.  There's always the genuine RePackr too.
Mobilis in Mobili
68 In progress
Well, it is not running on MS Office 2016 or MS 365 either. If anything I get run time error "6".
That is interesting. Just double checked by downloading the copy I posted and found a couple of bugs that might have causing the problem. Should be fixed now. Thank you for the feedback, doesn't help anyone if it doesn't work.
Can someone please confirm the new file works for them?
Mobilis in Mobili
68 In progress
(06-10-2019, 02:02 AM)Nemo Wrote: That is interesting.  Just double checked by downloading the copy I posted and found a couple of bugs that might have causing the problem.  Should be fixed now.  Thank you for the feedback, doesn't help anyone if it doesn't work.
Re-downloaded and found that there is still a problem.
Error Description would help.  Ran some more checks and found another bug, but don't know if its the one you got.  Clearly I need to beef up my error checking.  I did all my initial checks with IR included and never really tested without IR data in place.  Lesson Learned.
File's been updated again, any other alpha testers out there willing to download and tell me if its working or not?
Mobilis in Mobili
68 In progress
Nemo,
I works great for me with or without the IR Info plugged in.
If I take out the Cell Number I then get "Run-time error 6"
But then again the Sheet was designed to have cell numbers correlated with mAh tested results.
Works great for me.
