DIY DC combiner box
On request of some people a more indepth post of my DIY solar combinerbox.
This box is designed for my solar array which is still in a building phase.
Finally I will have 12 panels in a 3S - 4P combination.
The DC combinerbox will combine all the DC currents and add some extra safety features.
It all starts with a box...
Drill 14mm holes to fit the MC4 connectors.
Installing the MC4 connector with 10 gauge wire/2.5mm.
Preparing the schottky diodes and drill holes 3.5mm and taper 4mm thread into the heat sink.
Use some coolpaste before installing them on the heat sink.
A test layout...
Wire it all up, the terminal blocks are awesome, I found it by coincidence while browsing on AE.
I used Solar cable (6mm) between terminal block and DC breaker & terminal block and surge protection device.
Terminal block, 6 in - 2 out.
Don't forget to install the fuses....
Diagram....sorry I'm not that good at it, if not clear don't hesitate to ask me a question.
Data sheet schottky diode.
These are the links to all hardware I used to build this unit. Except the enclosure & heatsink which I had lying around from previous projects.
Cap fuse holder
https://www.aliexpress.com/item/32695643760.html
I use 10A fuses
https://www.aliexpress.com/item/32946610764.html
DC breaker:
https://www.aliexpress.com/item/32940325595.html
Surge protection
https://www.aliexpress.com/item/32890590691.html
Terminal block
https://www.aliexpress.com/item/32946942889.html
High power zener diodes
https://www.aliexpress.com/item/1412597935.html
MC4 connector
https://www.aliexpress.com/item/32835142335.html
Cupper lugs between fuse holders/zener & zener/terminal block
https://www.aliexpress.com/item/32846486368.html
Used tools:
MC4 crimptool
https://www.aliexpress.com/item/32882304975.html
Wire stripper:
https://www.aliexpress.com/item/32955348322.html
Good luck building your own, and again, don't hesitate to ask questions. Feedback appreciated too.
Frank
hbpowerwall, wim, RikH And 3 others like this post
Great job, I will be copying this design, due to the price of a commercial combiner box
Franky Beuselinck likes this post
