Best way to discharge to 3.7 Volts?
Hi everybody,
just started to build my own small battery with 18650.
I startet to test some cells voltage drop after 1 month. After finishing the voltage drop test i want to ask how you discharge all 18650s to 3.7 or 3.6 for storage or building the packs?
I noticed that you can change settings on an opus charger to 3.7volts. But for this you have to discharge the cell complete an load them again. I guess somebody has a good idea to get them better to 3.7 or 3.6 volts.
Thanks!
regards Christian
Quite easy.
Build yourself a 20p (or however many cells you want to put in parallel) discharge board.
Get a ZHIYU® ZB206 and set it to discharge to 3.6V at whatever amperage you want and you are done. Bonus is it will tell you how many Ahs you have discharged.
You can also use an iCharger to do the same just more expensive.
I'm sure there are other ways but this is the easiest way I have found.
bogptrsn and BlueSwordM like this post
Oh cool. I wanted to do the same thing, but I had spare time on my OPUS, so was just using it to discharge. Curious to see hear what others are doing.
Mobilis in Mobili
Cell count as of 10/10/2019
191 Cells of Everything Else
68 In progress
More info on my Google Drive
After discharge to 2.8v with the zb2l3 to get the capacity, i charge them back up with a cc/cv converter to 3.45 volts
I dont. I build en as is....
