Who knows this 13S 60A programable BMS from AliEx
Hi folks,
anyone knows or has exeperience with this BMS. It is a 13S 60A BMS, able to interface with bluethooth (App) and UART (PC).
https://de.aliexpress.com/item/10-S-36-V-60A-40A-30A-20A-Li-Ion-smart-bms-pcm-mit-android-Bluetooth/32966540730.html?spm=a2g0o.cart.0.0.7f0f3c00qCyMoo
I want to use it for a 8S Li-Ion Battery.
And yes, the BT- or UART-dongles are not included.
https://youtu.be/ClGmMY0kXvQ
Cross check you can run it on 8s...
Thanks!
He seems not quite sure about running it with less than 14s.
Anyways. It seems to have still some major issues with the software.
Can you recomment another 8s programmable BMS?
https://de.aliexpress.com/item/Smart-bms...fa1dfe9-38
I've bought 14s 100A 1.5 years ago, so far so good
I am using the 10s Version.
Except of the gruesome App, every technical aspect looks good.
I am not sure about using them on different cellcount as delivered.
1 kWp in Test
Ultra low cost
(06-19-2019, 02:40 AM)Cherry67 Wrote: I am not sure about using them on different cellcount as delivered.
You can't. If you don't use a cable it will trigger under voltage alarm.
Fisically the chip have a fix number of inputs and datasheet show how to join certain pins if you want to use less than the max. But I supose you must modify the firmware to tell it you have that number.
You can check a long thread about this BMS here.
Regards
(06-19-2019, 12:01 PM)energy_man Wrote:
(06-19-2019, 03:42 AM)jesusangel Wrote:
(06-19-2019, 02:40 AM)Cherry67 Wrote: Onları, teslim edildikleri gibi farklı cellcount'larda kullanmaktan emin değilim.
Yapamazsın Kablo kullanmazsanız, voltaj alarmı altında tetikleyecektir.
Mali olarak, çipte sabit sayıda giriş vardır ve veri sayfası, maks. Değerden daha az kullanmak istiyorsanız, belirli pimlerin nasıl birleştirileceğini gösterir. Ancak, bu numaraya sahip olduğunuzu söylemek için bellenimi değiştirmeniz gerektiğini düşünüyorum.
Bu BMS ile ilgili uzun bir ipucunu buradan kontrol edebilirsiniz  .
Saygılarımızla
Özür dilerim ama araya girip bişi sormak istiyorum.
Türkçe yazdığım için üzgünüm Sad
BMS gurupları 13 es 48 v iken neden 14S Paketler oluşturuluyor.
elimde 1800 adet 2300+  lityum iyon pil var
The language of the forum is english, please translate from turkish to english before posting I'm not moderator but these are the rules.
About the 13S -14S matter, normally a 48V inverter ready for lead acid battery only will handle a maximun of 13.8*4=55.2V or similar, so for using li-ion battery the best configuration is 13S (55.2/4.2=13.14), modern inverters and ready for li-ion have a wide voltage range even been rated for 48V, up to 66V in my inverter, for heavy loads it is better to work with higher voltage, so you can use 14S and even 15S.
People normally use standards, 7S for 24V and if you double that you have 14S for 48V, but the inverter only see volts range, most of us have choosen 14S but you can chose whatever number in series you want, the only limitation is the inverter, you can buy BMS for any amount of series.
Regards
Most inverters for LA 48v do 58V. I have not seen many doing less and thats due to bulk/float levels of some LA and the fact that you have voltage drop. With that said there are lower ones and higher but rare. 58-60 are the most common and therefore 14s is one of the better choices.
Choosing for instance 15s and think that serves a purpose and instead only being able to charge to 4v is not correct thinking. You should avoid push the inverter to its limits and this especially applies to cheap ones due to the components inside.... Also they arent more efficient going to its limits either.
The current savings and loss savings in wires going higher is not much since you rarely push it that much. In that sense its better to stay in middle Smile
I found one that is a bit more expensive (hear hear), but has higher current capability and more "s". You can run it from 7 to 16s (or 17 to 20 depending on model) for sure. It is rated for 100A instead of 60A for the first I had in mind. That gives me about 50A continuos. A bit more if I put some heat sinks on it. It has a build in BT-Module and temperature sensor function.
Anyone knows about this BMS and can tell me more?
https://de.aliexpress.com/item/Smart-7-S...42943e1-36
Attached Files Image(s)
Since no one is anwering, I will go ahead and order the 7-16s 100A BMS. It gives me the possibility to upgrade my 8s System (24V-Inverter with input voltage up to 32V !) to a 16s System (48V Inverter).
Because there are not many feedbacks on aliexpress for this BMS,  it seems to be pretty new on the market. The seller already replied to a few of my questions.
I would certainly report back on this BMS, if I only knew for certain that the moderator keeps the threads clean from off topic comments and silly people that do not understand the rules.
