12v Horse Lorry Replacement Pack
Hi All
My wife has seen me messing around with cells for a couple of years now and has decided I need to do something for her now.
She has a horse lorry with a 12v leisure battery system with an inverter and solar panels on the roof. On occasion she can run out of power due to our lovely Scottish weather (no sun) so I am planning to replace the leisure battery with a bigger 18650 pack consisting of approx 360 cells. Basically the questions are...
Do I go for a 3s or 4s pack?
Any suggestions for a BMS as there could be a potential 100A draw on the pack for short periods?
Anything else I can do to minimise the chances of setting her truck on fire!
The inverter/charge is this device which is installed already...https://voltaconsolar.com/off-grid/12v-off-grid-inverter-charger/conversol-1500va-12v-inverter-charger-mppt.html
Thanks for any help.
Cheers
Go with LiFePO4 cells to make things a LOT easier to size. They can directly replace lead acid without over-charging. They also can handle higher amp draw
(06-25-2019, 10:56 PM)Korishan Wrote: Go with LiFePO4 cells to make things a LOT easier to size. They can directly replace lead acid without over-charging. They also can handle higher amp draw
Thanks for the reply however 18650's is what I've got unfortunately. Lots of them.
If you can't switch over, then it'd be best to go with 4s. It's easier to bring the voltage down than trying to bring it up.
What all do you need to run off battery? I'm not sure exactly what "horse lorry" your wife has. There's lots of results for "lorry" Wink
If this is like a golf cart type device, then 16V for an electric motor isn't going to hurt it. It will actually run a little more efficient than at 14V because it'll pull less amps, therefore less heat generation/wasted.
18650 is not a chemistry. LiFePo4 exist in that form factor tio.
I also vote LiFe cells. LiIon doesnt Play well with 12v depending on system.
How do you charge?
What Will it Power?
Korishan higher voltage and less current doesnt automatically mean less wasted energy.... Also IF There is a motorcontroller between that might blow Up over 15v. Unknown factors Wink
I'd go 4s, 12V control electronics can be run from a buck regulator & motor current controlled via a decent PWM contoller
24 User(s) read this thread:
daromer (07-29-2019, 08:35 AM), Jonas Vanbeveren (09-01-2019, 10:41 AM), 100fuegos (06-26-2019, 08:12 PM), Klug (07-03-2019, 03:33 PM), Lekr (06-28-2019, 05:10 PM), Generic (06-26-2019, 03:46 AM), stevelectric (06-26-2019, 11:36 AM), ajw22 (06-26-2019, 12:00 PM), OffGridInTheCity (06-26-2019, 02:00 AM), offgrid2020 (06-25-2019, 11:06 PM), curnowdj (06-29-2019, 06:40 AM), Redpacket (06-26-2019, 10:55 AM), Crimp Daddy (06-25-2019, 11:16 PM), Sean (06-26-2019, 12:54 PM), Korishan (06-26-2019, 02:03 PM), PAF (06-26-2019, 01:25 PM), Asylumweb (06-26-2019, 11:24 AM), jdeadman (06-26-2019, 02:28 AM), wim (06-26-2019, 06:39 AM), watts-on (06-27-2019, 01:02 PM), Geek (06-27-2019, 11:24 PM), djuro (06-27-2019, 07:43 PM), Headrc (06-26-2019, 12:33 AM), dennis11 (07-18-2019, 03:50 PM)
