locking for cheap configurable BMS for extended e-bike battery
Hi,
Until I have enough Cells to build my own Powerwall I'm using temporay 3 times  36V e-bike batteries that I extended to 48V.
To not destroy them when they are in use I need some kind of BMS that is configurable to use the Batteries only between 4.0V and 3.5V.
I already tested the smart BMS that Daromer used for a 1kWh Pack, but would need three of this type for my 3 Batteries
and 50€ each is to expensive from my point of view.
So does anybody know a cheap confgurable BMS that I can add to each 48V Module and set it between 3.5v and 4V?
regards
cadric
2. Offgrid System 09.2019 7,5 kWp: 25 x 300Wp Solarworld (5x( 3S + 2S )), 2x PIP-5048MS, Batrium WM4, 1st Battery Bank: 840 cells in 14S60P with 80Ah cap.
Use One of them and Connect the batteries to 1.
(07-07-2019, 06:53 PM)daromer Wrote: Use One of them and Connect the batteries to 1.
Hi daromer,
yes that is what I also thought, after asking this question, thanks for supporting me to that solution.
I will try to build some kind of a bus connector to parallel connect all e-bike Batteries I have that way....
regards
cadric
29 User(s) read this thread:
daromer (07-08-2019, 07:38 AM), Bayyn (07-23-2019, 10:59 AM), ajw22 (07-09-2019, 07:11 AM), OffGridInTheCity (07-08-2019, 02:26 PM), Maniac_Powerwall (10-20-2019, 03:03 PM), JBonesaw (07-08-2019, 05:56 PM), juanjo57 (07-09-2019, 05:42 PM), tachion (07-08-2019, 07:50 PM), stok (07-23-2019, 12:13 PM), Rexyboy (07-09-2019, 10:39 AM), HazeWare (07-07-2019, 09:41 PM), jiggyjonboat (08-13-2019, 11:32 PM), elkooo (08-09-2019, 02:18 PM), risoman (10-05-2019, 08:19 PM), chuckp (07-08-2019, 11:25 PM), Riplash (07-08-2019, 12:45 AM), Sean (07-08-2019, 08:18 AM), Majorphill (08-18-2019, 07:45 AM), Korishan (07-08-2019, 11:44 AM), jdeadman (07-09-2019, 05:18 AM), Stefaan De Ridder (07-08-2019, 01:52 PM), Geek (07-09-2019, 12:58 AM), djuro (07-09-2019, 06:04 AM), HughF (07-08-2019, 01:39 PM), jonyjoe505 (07-12-2019, 03:58 AM), cadric (07-26-2019, 07:06 AM), Bubba (07-08-2019, 09:43 PM), Cherry67 (07-13-2019, 09:13 PM), papanyan (09-28-2019, 08:41 AM)
