Threads: 13
0
Total Cells: 320
Total Capacity: 2.25 kWh
I have been using my 4s setup for awhile. I am ready to go to a 7s.
So my question, should I tear apart my existing packs, retest all the cells, add them in with my other cells and build 7 new?
Or would it be ok to add 3 more packs?
I have a bms so I am guessing adding 3 more isn’t a terrible idea, but I’m guessing not ideal.
Would like some feedback before I proceed either way lol.
Thanks!
Threads: 191
72
Total Cells: 10
Total Capacity: 0.08 kWh
If the 4s has been performing just fine, adding 3s should be fine. Just make sure the new packs have the same capacity as the existing packs, or at least within 100-200mAh of the others.
Proceed with caution. Knowledge is Power! Literally!
Please come join in general chit-chat and randomness at Discord Chat (channels: general, 3d-printing, linux&coding, 18650, humor, ...)
Threads: 191
72
Total Cells: 10
it'd be good to double check each packs capacity to verify their integrity. No need to pull the packs apart, just connect to each Pos/Neg of each parallel segment and charge/discharge-test. Then you'll know what you need to aim for in the added packs
Threads: 191
72
Total Cells: 10
Create a resistive load, old toaster element, hair dryer element, you could even take some stripped 12AWG copper wire and coil it until you get 1-Ohm. Or you could go higher on the Ohms until you get something like 10A or such. Use a clamp meter or a shunt to measure the amps. Watch the voltage drop and keep track of the amps.
1A discharge over 1H = 1Ah (1000mAh)
If discharging at 10A
10A discharge over 1H = 10Ah (10000mAh)
CrankyCoder likes this post
Threads: 13
0
Total Cells: 320
i have some power resistors i could probably use in series to do that. Ill give that a go! Thanks!
Threads: 13
0
Total Cells: 320
I think i can use 3 x 1ohm 100watt resistors with a heatsink/fan.
Then just do some voltage monitoring with the an arduino just like my other testers. just need to compensate for that much higher amperage for cooling, wires and connectors.
Ill post an update when I have something in place.
Threads: 4
8
Total Cells: 5034
Total Capacity: 40.34 kWh
I had a similar issue going from 7s to 14s. I made the 7 new packs with same technique (similar ah) and then used Batrium BMS to discover packs a bit weak. For those weak packs, I added a few more cells and after a few rounds of this - had a balanced battery. Of course, this technique requires Batrium BMS and pack design that supports more or less cells by a few.
Threads: 13
0
Total Cells: 320
That could work too! my packs are all 1s80p. no reason they couldn't be adjusted to 1s85p if needed. Ill keep that in mind.
