Parallel or Series
I have 48 Nissan Leafs modules.
For cell balancing, no BMS as yet, the question is would it best to have 6 modules stacked in parallel, then 8 in series or 8 modules stacked in series then 6 in parallel. Both would be charged to 64v,
Thanks
Radian 8048A/GSLC, FlexNet DC, Mate 3s, HUB 10.3, FM80 (2), Hanwha QCELLS 320 (24), TechLuck SHHWC (3/24), Leaf Modules (98), Hyper Engineering Sure Start
(07-08-2019, 02:41 PM)gpearce52 Wrote: I have 48 Nissan Leafs modules.
Thanks
Voltage wise it would be the same result as you know.
If you do 6p8s The BMS solution would be the easiest. 1 8s BMS
If you go pure 8s you would need to get 1 8s BMS for each string so in essence 6 BMSs
If you tie the junctions together in the 8s you are back to a 6p8s anyway.
Sean likes this post
Last count as of 8/7/2019
For Info Google Drive
Check out this post from Stephen Kunkel and the link he posted about parallel battery packs. A single BMS is easier and more secure. I'm using parallel packs with parallel BMS'es, but each BMS can disconnect its pack from the main bus - a setup which slightly differs from your second drawing.
Little off topic, sorry, but i would like to know.
@ Wolf, how do you do those drawings.
Probably a stupid question, but the only stupid question is the one that you never asked.
I am also not much of a computer person.
I stopped after c basic (:...
Thanks
1500 waiting for testing.
3 chargers?
With best regards
(07-10-2019, 01:12 PM)100kwh-hunter Wrote: Little off topic, sorry, but i would like to know.
Thanks
Basic MS progie called "Paint" and a little bit of patience.
There are others but for a quick representation of a concept it works well
One of the interesting things about Batrium is that it is a 'single BMS' that monitors / balances either configuration. You can put 1 longmon per cell (as in bottom picture) or 1 longmon per parallized cell (upper picture)... BUT as demonstrated by @HBPowerwall you can put multiple longmons on a single cell... and choose to achieve a wide range of balanace amps per cell regardless of how you build the battery.
The main driver for me (these days - after a year of operation) is how to detect and replace individual 'cells' (packs) as the battery weakens over time. So its a matter of 1) detection and 2) physical 'ease' to unhook/replace/rehook individual cells my guiding design.
Thanks Wolf, I tried but it's not my thingy, I will keep on using paper and pencil.
Not patient enough, I am a person that gives computer aggression an extra dimension.
@offgridinthecity, interesting data!
https://www.aliexpress.com/item/32883863452.html?spm=a2g0s.9042311.0.0.f5524c4dCY1Fol
I bought this one, to monitor every year the deterioration of the pack(s)
I am planning(for now) to take out next year, every year a whole pack(14 of them) and test them
3 chargers?
With best regards
51 User(s) read this thread:
HRD (10-11-2019, 06:51 PM), JBonesaw (07-08-2019, 04:19 PM), 100kwh-hunter (07-10-2019, 06:08 PM), Rubert (07-10-2019, 06:08 AM), rearden (07-22-2019, 12:22 PM), OffGridInTheCity (07-10-2019, 04:15 PM), Lagachette (07-09-2019, 11:56 AM), ajw22 (07-11-2019, 04:40 AM), stevelectric (07-11-2019, 10:31 PM), Solardad (07-09-2019, 01:00 AM), Wolf (07-10-2019, 06:06 PM), gpearce52 (07-24-2019, 07:02 PM), billvon (07-11-2019, 02:22 AM), Androfire (07-10-2019, 02:17 PM), SammyC (09-18-2019, 02:12 AM), MBard (08-22-2019, 10:48 AM), JGrooms (08-08-2019, 05:15 AM), jiggyjonboat (08-04-2019, 03:21 PM), EnergyInternet (07-23-2019, 09:30 PM), sivabhaskar070 (07-23-2019, 10:46 AM), evbkz (07-25-2019, 10:20 AM), heiko (07-09-2019, 10:52 AM), stok (07-15-2019, 01:51 PM), krobertson (07-10-2019, 04:20 PM), Klug (09-12-2019, 04:22 PM), WuggyBuggy (07-08-2019, 06:49 PM), chuckp (08-22-2019, 03:31 PM), Geek (07-11-2019, 02:06 AM), jesusangel (07-10-2019, 07:21 PM), wim (07-10-2019, 06:14 PM), jdeadman (07-09-2019, 01:16 PM), Korishan (07-10-2019, 07:08 PM), Majorphill (07-22-2019, 01:01 AM), owitte (07-10-2019, 05:24 PM), mike (07-09-2019, 12:15 PM), Sean (07-10-2019, 06:46 PM), daromer (07-10-2019, 06:33 PM), drchips (07-10-2019, 02:38 PM), Issac (07-10-2019, 09:17 AM), Crimp Daddy (07-15-2019, 09:42 PM), Buzz0515 (07-15-2019, 09:32 PM), Sammm (07-10-2019, 01:11 AM), HikingGuy42 (07-09-2019, 12:36 PM), 100fuegos (07-08-2019, 08:54 PM), Riplash (07-10-2019, 10:58 PM), Walde (07-11-2019, 10:09 AM), Sholphin02 (07-09-2019, 02:53 AM), oilskov (07-11-2019, 12:19 PM), Zvonko000 (07-14-2019, 08:38 AM), Ibiza (07-08-2019, 06:01 PM), hbpowerwall (07-23-2019, 08:22 PM)
