Mppsolar Inverter - Re discharge voltage issue
can someone confirm that, despite of re discharge voltage value (in my case 53V, program 13) these inverters restart only when battery is fully charged?
Low voltage cut off function (48.8V) works as aspected but inverters wont restart till battery is fully charged (60V) again.
My system is totally off grid.
Same experience?
What inverter?
The one I have I set shut off voltage and re-engage voltage. So for insance Shut off at 48V and then reengage at 50V.
(07-09-2019, 11:55 AM)daromer Wrote: What inverter?
I have 3 inverters PIP5048MG for a 3 phase system.
Shut off voltage is set to 48.8V and works.
Re-discharge voltage or re-engage voltage (function 13) is set to 53V but it doesn't work.
PS I have another 1 phase system (same inverter, PIP5048MG) with same behavior.
My 2424LV Turns back on when I set it
The re-discharge-voltage (13) corresponds to the recharge-voltage (12) and controls the bypass switch from battery to grid power. Imho there is no such corresponding setting for the low-dc-cutoff-voltage (29) which powers off the PIP completely. So I guess the behaviour you see is not configurable.
Edit: the manual lists a "High DC Recovery Voltage" being 58Vdc or 62Vdc in the specifications.
(07-09-2019, 01:15 PM)jdeadman Wrote: My 2424LV Turns back on when I set it
What’s your program 1 selection?
(07-09-2019, 01:21 PM)stevelectric Wrote: The re-discharge-voltage (13) corresponds to the recharge-voltage (12) and controls the bypass switch from battery to grid power. Imho there is no such corresponding setting for the low-dc-cutoff-voltage (29) which powers off the PIP completely. So I guess the behaviour you see is not configurable.
Perfectly understand what you say about program 12 and 13 but can’t imagine an off grid inverter with no point back voltage activation.
Ps: where you found the High DC Recovery Voltage?
(07-09-2019, 02:21 PM)iomagico Wrote: Ps: where you found the High DC Recovery Voltage?
But thats for High DC and not low DC. 2 different scenarios. High is for protection for internal components basically.
@Daromer, you are right! I must be mistaken here, this is something different.
I'll check when I get home
iomagico likes this post
