Council
I need the approval of the consul to continue.....
Be honest and look close
Selling everything at marketplace.
Closer image?
(07-12-2019, 05:55 PM)100kwh-hunter Wrote: I need the approval of the consul to continue.....
Well, I'm certainly not on the consul and I wouldn't wait for any approval from me Smile
And - sounds like congratulations are in order!!
One thing I did was added empty 4x4 battery holder next to the power lugs on each end of the pack...  this protects the lugs from just 'sticking out there' and possible bumping in to things / shorting out.  It also lets me set the pack vertically.    And it turns out that it gave me a place to add a few cells to 'balance' the pack later.
The yellow circles look like solder joints that are either too cold (lumpy) or the wire isn't fully covered by the solder. These should be reflowed to get better contact. I couldn't clearly see the ones on the right side, so there may be more needing attention.
@ OffGridInTheCity,
Thanks.
To "balance the packs" I had a similar idea.
I am going to charge every pack up to 4 volts and discharge them with a 180w discharger.
Write those numbers down on the pack itself.
When i have completed 3 strings of 14 packs each, it is going to be easy to add up the numbers, and make a small pack to even the numbers, and connect that as a "4" string, so basically every 300 cell pack will have the same amount of amp.
But per pack i think you're idea is better and simpler.
@ Korishan,
Thanks, i am busy with it, there are indeed some wires that could use some more tin, also on the busbar.
Inpatient is written all over
43 User(s) read this thread:
skyricho (08-20-2019, 12:57 PM), 100kwh-hunter (07-18-2019, 03:32 PM), OffGridInTheCity (07-13-2019, 07:21 PM), kevinjaye (07-15-2019, 05:38 AM), RikH (07-15-2019, 03:37 AM), ajw22 (07-13-2019, 11:53 AM), BigDav (09-02-2019, 09:27 PM), Chass90 (09-15-2019, 05:43 PM), Katarn_89 (07-19-2019, 03:21 AM), Nemo (07-16-2019, 06:37 PM), billvon (07-12-2019, 07:42 PM), Saiya (07-15-2019, 04:56 PM), dragonfly (08-20-2019, 03:13 PM), Alek604 (07-25-2019, 01:46 AM), Otakar (08-03-2019, 10:27 PM), evbkz (07-20-2019, 04:41 AM), Jonisingt35r (07-21-2019, 10:01 AM), Slayer1 (07-14-2019, 06:01 AM), stok (07-15-2019, 11:59 AM), krobertson (07-13-2019, 10:31 PM), 100fuegos (07-17-2019, 08:23 PM), Riplash (07-13-2019, 03:02 PM), farmerjohn (07-20-2019, 09:05 PM), watts-on (07-13-2019, 02:34 PM), wim (07-13-2019, 02:30 PM), jdeadman (07-15-2019, 03:06 AM), PAF (07-12-2019, 07:23 PM), Korishan (07-13-2019, 11:05 AM), Majorphill (07-22-2019, 12:59 AM), mike (07-13-2019, 02:32 AM), Sean (07-13-2019, 11:25 AM), Hanssing (07-13-2019, 06:15 PM), BlueSwordM (07-15-2019, 12:56 AM), Geek (07-15-2019, 12:17 AM), Oliman (07-13-2019, 01:44 AM), Ibiza (07-13-2019, 04:47 PM), Crimp Daddy (07-12-2019, 06:28 PM), rogales141 (08-27-2019, 07:00 AM), drchips (07-13-2019, 12:46 AM), sturgeo (07-19-2019, 07:13 AM), CarelHassink (07-13-2019, 01:38 PM), Oz18650 (07-16-2019, 01:54 PM), daromer (07-13-2019, 07:10 PM)
