100kwh-hunter
Active member
- Joined
- Mar 2, 2019
- Messages
- 1,355
Was tinkering in the shed and I was thinking of the following.
My wall is going to be as the drawing on the paper, on the wall: in sections.
So every pack will have its own "room"
Every room will be covered with plaster sheet that can with hold 1000 degrees celsius for over half an hour.
The packs will be covert with sand, so the flame of the cell will blow out the sand(1cm thick) but its sparks will not reach the other cells or the other packs...that's why the room idea.
The flame will meet the plaster that will have time enough to resist the flame for 30 min.
I did not have time enough to make the headboard on the housing of the pack.
But the head board will hold a ventilator to cool off the pack, that seem to be necessary.
Seems the cells will warm up when in use.
Those ventilators i will order on alibaba for...what...1 euro a piece?
They will be connected to there own power line so they don't have a draw on the packs it self, connected with a capacitor, to give them one minute or so to cool of the packs after minimum voltage is reached.
Before the cells are covert with 1 cm of sand, it obvious to work on the edges where the holder meets the wood.
With some ?acrylaatkit?(in dutch its "acrylaatkit", don't know the english word sorry).
I think the wish would be fine grain sand, like play sand.
In the picture is my first pack, that one is not going into the test fase, got a test pack for this.
How do i set one cell of? charge it on 8v?for testing on a safe distance and place and remote ofcourse
Any thoughts on this subject, or comments...everything is welcome
Thought help comment are really appreciated and welcome, i would like to create a cheap safe and workable idea.
Thanks in advance, best Igora
Why is my paper upside down......
