7s config balancing question
(07-16-2019, 02:58 PM)MattBarnesJCKS Wrote:
(07-16-2019, 11:56 AM)daromer Wrote: You end up with that because you dont have a BMS that do balancing as you need it to do.
Thats also the reason why you need a BMS with proper balancing functionality Smile
Correct.  That's my issue.  How to keep it bottom balanced...
The balance at the end of a discharge cycle will depend on how closely matched your cells capacity are, combined with the BMSs ability to actively balance (few do) - top balanced packs are the norm here.
Why bottom? Its not in the bortom you Will see issues. Overcharge cells are 100* more dangerous than undrcharged. I would highldy recommend top balanced battery bank or use active balancing.
Systems that do bottom are rare
I concur with Daromer. Top Balance with cutoff at at lease 3.5V/cell as to not let a bad cell get too low
Cut off should be 3 or even 2.8... on bms Side that is. In this case the Ups decides total voltage cut out
