LiitoKala Voltage reading wrong by -0.30V
(07-22-2019, 01:55 AM)Geek Wrote:
(07-19-2019, 12:31 PM)barns Wrote: I appreciate the MM concerns but that's not the issue.
There are reasons why most would jump to the conclusion of your MM.
It’s a classic case of MM denial… I’ve suffered though it for years.  I now have at least 4-5 meters just to make sure my others are not lying to me.
Geek likes this post
(07-22-2019, 06:21 PM)Crimp Daddy Wrote: It’s a classic case of MM denial… I’ve suffered though it for years.  I now have at least 4-5 meters just to make sure my others are not lying to me.
Yep I've had my share of MM doubt till I bought 2 things well 4 things actually
1. A Voltage reference unit and a resistor reference.
2. A decent Bench MM. well 2.
Big Grin Big Grin Big Grin
Last count as of 8/7/2019
For Info Google Drive
Nice toys. Don't have the budget for those unfortunately. Where'd you get the Voltage reference unit?
I've got 8x INA219 sensors for my DIY charger/discharger project. I hope the readings from those will be good enough to confirm that my MM and Opus are not that broken.
(08-01-2019, 09:04 AM)barns Wrote: Nice toys. Don't have the budget for those unfortunately. Where'd you get the Voltage reference unit?
Voltage reference unit. AD548
https://www.amazon.com/gp/product/B00NL4...UTF8&psc=1
Just google AD548 and you will find many variation to it.
The INA219 ar good little units. They have their own internal reference V I believe.
Just got to write the sketch and still do the calculations and as I have found out with V dividers and even the ADS1015 and/or the ADS1115.
Still had to do some offset calculations. So having the fluke meters helps.
You can occasionally find a good deal on a decent bench MM for under $100 on ebay.
(08-01-2019, 12:54 PM)Wolf Wrote: Voltage reference unit. AD548
Have you tried the AD584? AD548 does not seem to be for sale on my country's online shops. I found similar looking builds but marked as AD584.
(08-01-2019, 02:17 PM)barns Wrote: Have you tried the AD584? AD548 does not seem to be for sale on my country's online shops. I found similar looking builds but marked as AD584.
The AD584 seems to be the same idea.
https://nl.aliexpress.com/item/328639026...lsrc=aw.ds
Just the numbers are different Huh
(07-18-2019, 11:47 AM)barns Wrote:
(07-18-2019, 12:03 AM)Crimp Daddy Wrote: Sounds like its ready for the trash bin...  those testers dont last forever, I have lost a couple to heavy use.  Once they start acting up I retire the unit.
Oh boy, it's only 8 months old and have tested less than 200 cells.
Donate it to me for repair?
No. cells
Indexed: 53
Processed ok, not yet indexed: ~3200
Broken down, untested: ~0
Not yet broken down: ~200 kg
There are reasons why most would jump to the conclusion of your MM. I'm not certain, but I don't really think an 18650 could even hold 4.55v. I sure wouldn't even like to test it. I imagine somewhere around 4.3-4.4v it would just start burning off the charge as heat. The cell most assuredly would be hot when removed from the charger. It would most likely trigger the CID.
If you were sure that a cell actually hit 4.55v, I would discharge and bin it. The useful life has most likely been cooked out of it. I would definitely handle with care, as it most likely will have some pressure built up inside.
are you sure????
I think pretty much every cell will go to 5V.
wouldn't want to do it by accident.  and I don't do it on purpose.  but I've found cells dumped from 'harvesters' (shame!) at this SoC.. it's not the end of the world ... but definitely out of spec.
Btw the overcharged cells are https://secondlifestorage.com/t-LG-LGABD...ifications and https://secondlifestorage.com/t-LG-LGABC...ifications which has a max of 4.35v and 4.30v.
@winny
Sorry, I'm from asia and shipping would probably cost 2x a brand new unit lol.
are you sure????
I had a LiPo that I accidentally overcharged, LiHv setting - 4.35v instead of 4.2. It swelled up like a balloon. I don't know what voltage it hit, as I disconnected the charger immediately.
