That depends on what you are going to put in and take out.
I will charge with ~500-600 mah per cell and discharge with ~200mah per cell.
But my wall is growing, so it will getting less and less per cell.
If you know what current draw there would be(charge or discharge) i would take 3 or four times the amount.
If you are going to charge with 1.5 amp a cell, then i don't think you want 1 amp fuses
A fuse is only for short circuit protection, so if your cell can handle 5 amp, you can do with 3 or 4 amp fuses.
But this is what i think.
What i also think:, i don't like "fuse wire", in case of a self discharger, the fuse wire will go very slow.
There is a point that it will form a glowing metal ball, i am not very fond of the idea that there is a possibility of a molting ball of metal in a place where i don't want him
To solder those fuses to your busbar there is a trick or two.
I like to twain two fuses together, and snip off half of the other end, bend them and then solder them, cell first.
Bend/fold the other end into the busbar, it will save you some burning marks or fiddling around with a extra tool(thus a extra step in the process)
Will make some picture's if wanted.
My two cents, hope this was helpful, best
