Any BMS thats work's with sofar solar ME3000SP
So just wondering if anyone has managed to couple up any BMS to the sofar solar ME3000sp?
I have the darfon/growatt 5kwh battery pack and i have given up on the built in BMS
So any help on this matter would be much appreciated, I would rather something cheaper than Batrium but would use it if someone could actually confirm they have had the pair working.
Many thanks
(07-19-2019, 03:16 PM)BobInHD Wrote: So just wondering if anyone has managed to couple up any BMS to the sofar solar ME3000sp?
Many thanks
V3 watchmon here working with Me3000 for 2 years. Also gave up on the built in bms in growatt battery
You could also use the me3000 in standard lead acid battery mode (no bms connection to Me3000) with a chargery bms (have done this as well)
4 kw grid tied system with fit further 2 Kw without.
5 kWh 12v lead acid off grid system, used as a ups for my servers and network and to provide house power incase of power failure
10 kWh 48v lifep04, Batrium BMS, charged from me3000 sp
5 Kwh Growatt sp2000 connected to separate 2 Kw system
me3000 sp enables maximum use of solar without exporting to grid
Thanks for the information KtB there is not much out there regarding the growatt battery, Did you ever get the growatt BMS to talk to the me3000? i have 2 boards now and cant seem to get either to talk to the me3000, maybe i am wiring into the wrong place?
Hi guys
Just received my ME3000SP, going to fit it today/tomorrow.
UK Southwest.
(08-24-2019, 10:04 AM)BobInHD Wrote: Thanks for the information KtB there is not much out there regarding the growatt battery, Did you ever get the growatt BMS to talk to the me3000? i have 2 boards now and cant seem to get either to talk to the me3000, maybe i am wiring into the wrong place?
No I just gave up as there is zero information about the bms that I could find and with 8 wires to try it was just not worth it.
