Overmind said:May you have an efficient disassembly.
You should extract all the cells 1st, then start sorting.
Doing it one pack at a time it's quite inefficient.
OffGridInTheCity said:Watch out - its very addicting... this will likely only be thebeginning
mike said:That's a lot of batteries
100kwh-hunter said:in my view it's not enough ... my mind it's lost on this. Big Grin Big Grin Big Grin
There are more ways to get more cells....ebike, scooters ect
Some ebike contains also those squire bloks, you can use them after testing, but the outer case is the positive side, remember that please.
