Cells. Charger with discharging
I want to get a decent charger but do not have the budget for the top end models.
It seems to me that before deciding I need to decide what is optimum charge and discharge rate?
The safe bet would be 0.5amps for both charge and discharge but takes ages and makes one lean to a build your own, but you do not get display of mAh.
1A seems OK and even 1.5A, 2A seems to bit risky, however, from what I have seen this is only used to begin with and then drops all the way to 0.01A
Currently  I use an IMAX clone, charge a cell, then discharge it then charge it.  I keep those that hold their voltage and "review" those that don't
So you have the 4 unit chargers, these seem to go up to 1.5A, on Amazon you have 8 unit models but although they say they can do 1.5A I there seems to be a lot of doubt about whether they could do 8 at 1.5A at a time.
Most seem to lack a discharge capability, again I guess I could build a discharge setup, but it adds more complexity if I have to move and keep track of what stage they are at.
The top end charges have discharge but price is OTT
Am I missing something, because this far seems very hard to find a reasonably priced charger with discharge and at least 1A per bay and able to do 4 x 18650 at once, 1.5A would be a nice to have although I am sure some would say best to stick to 1A.
Your recommendations would be appreciated.
Could you tell us what you are trying to achieve?
Many people use cheap tp4056 modules for charging, which leaves thier (more expensive) devices to only do discharge/capacity testing.
It also seems that most people use 1A current during testing. There is a fair amount of discussion about heat and testers, so 1.5A might be an issue for heat?
I don't see how you can really get that much cheaper than a liitokala lii-500... ordered from China I paid $78.26 for 6 units shipped. That's $13 per charger/discharged. I won't even bother to try and build one for less using TP4056 and separate discharges.
That said, hobby chargers (like the iCharger units) are great too, really my tool of choice, they are just terrible at high volume processing. That said, I use them to test completed modules or packs which is where its strengths are.
18650 and Geek like this post
I don't know where you are from but i sell mine.
Maybe its what you want.
Best
You can always charge cells in parallel with the IMAX. I use 2x 4 cell holders. I write the voltage on cells before I charge them, and add them as the voltage comes close enough. You shouldn't put two cells in parallel if they are more than 0.1v or so different. Would suggest putting fuses on such a setup, as putting a cell in backwards could be very hazardous. Also, using a piece of strap, or string under the cells makes for easy removal.
Buy a multi cell discharger such as the Liitokala or the Opus for testing. They often work out cheaper than buying the ZB2L3. However, the ZB2L3 can be used with higher current. As mentioned above these things can be had fairly cheaply. Just beware of clones and fakes.
Charging with a device other than your tester comes with a few advantages. If a cell leaks, it only damages a cheap cell holder. You can weed out self discharging cells, so as not to waste time testing them with your discharger.
I really like using a hobby charger with cell trays… I generally use it as a pre-charge with it before it even hits the discharge tester.  At least if I am processing a large amount of similar cells.  I typically mark the voltages and just keep hot-adding cells in parallel as the voltage increases when charging.  I also increase charge current when doing.
(07-22-2019, 10:20 PM)Oz18650 Wrote: Could you tell us what you are trying to achieve?
What I am trying to achieve is to buy a charger
I have some TP4056 but they do not tell me the mAh capacity of the cells
As I stated above you need an Opus or similar.
If you haven't bought a charger/discharger yet, I would opt for the SkyRC MC 3000. It costs more than the others, but if I knew about it before I started with an Opus, I would have definitely bought one.
You really want something to charge your cells, separate to your tester. As stated above.
For a add on, you could seek for the zb2l3 or simular.
Try
https://www.aliexpress.com/item/40000114...st=ae803_4.
18650 likes this post
(07-23-2019, 12:17 AM)Crimp Daddy Wrote: I don't see how you can really get that much cheaper than a liitokala lii-500... ordered from China I paid $78.26 for 6 units shipped.  That's $13 per charger/discharged.  I won't even bother to try and build one for less using TP4056 and separate discharges.
That seems to suit my needs exactly, I might have preferred more bays for the money or a lower price (based on Amazon) but I checked this review on YouTube
and it seems to have two discharge functions, although I think it is important to full discharge a cell then charge it fully to determine capacity.
I would have liked 1.5A but I can live with it.  Whenever I look at these chargers I am never sure if they are capable of charging the max bay capacity concurrently.  For example 4 bays with 2A input would suggest 2 / 4 so 0.5A per bay if 4 cells or 1A per cell per bay if 2 cells, HOWEVER, it is 2A at 12v so if it is charging at around 4.2v per cell that might suggest it can do more concurrently?
