07-23-2019, 04:17 PM
I've got a line on 2 forklift batteries. They are relatively new (3 years), but probably not well maintained. I believe I can get them fairly cheaply because the seller just wants them gone and doesn't seem to know their value. Charger is not available as far as I'm aware. Battery Specs are:
Type: DEKA 18-D125-15
Nominal Voltage: 36 V
Rated 6 Hr. A.H. Capacity: 875 A
Finish Rate: 44 Amps
Full charge Specific Gravity: 1.280-1.295
This would seem like a shortcut to setting up a beefy behind-the-meter system, but there are ALWAYS details and shortcuts are never as short as they first appear. I didn't think I'd be in this position for years, and even then with Li-ion, so I'm tossing it out to others who may have some good considerations. Unfortunately I don't have a lot of the info I'd like to make a decision, like household peak/total power draw, solar availability throughout the year etc. I am also trying to educate myself through other sites, but I value the feedback from this community most.
Key Questions
- Are there easy ways to check/confirm ballpark SOH without a full charge/discharge?
- Can I use in a grid tied, behind-the-meter solar set-up at 36V or should I consider rewiring the two batteries into one larger 24V system?
- Is this too big? I thought there might be limitation with lead-acid that there aren't with Li-ion
Thanks in advance for any feedback.
Key Questions
Mobilis in Mobili
Cell count as of 10/10/2019
234 Cells >2000mAh, >80% Rem. Cap., 14 day resting voltage >4.12V
191 Cells of Everything Else
68 In progress
More info on my Google Drive
68 In progress
