RttPowerWall
My name is Samuel I am Brazilian from Santa Catarina
My project is complete, it takes a 7s recycled lithium bank with 144 amps initially.
Swipower 3000 Watt Inverter, MPPT Controller SUN21 - CCS-M4024.
Soon more news here
hbpowerwall, chuckp, Korishan And 2 others like this post
More cells to the wall, soon we'll have updates  Big Grin Big Grin Big Grin
Wolf and Korishan like this post
Cool new name inverter!
Expecting the project!
rettore likes this post
Following this. Looks good so far!
<Tested Inventory Capacity 5.42 KWH>
Nice, and with plenty of space for battery expansion.
You've designed this for max 25kWh? I hope the case is really really well secured to the wall. It'll get quite heavy.
It looks like the battery case is well sealed, sitting outside in the sun. Have you measured how warm it gets inside the battery case? Heat is one of the killers of LiIon cells. You might want to put up some sort of shade. Or even add a thermostat controlled ventilation, if it should get hot inside.
(08-17-2019, 04:59 AM)ajw22 Wrote: Nice, and with plenty of space for battery expansion.
hello friend, she catches the sun around 1 hour in the morning only, but if it heats up I will add ventilation the project is still starting so much can change, thanks for your considerations will not be ignored tks
Good morning,
this is the working prototype of my inverter output monitoring application, and the utility input to my system, below is a graph in watts of near real time consumption (1 minute delay).
System developed with Raspberry, androi-studio integrating with google cloud (firestore and firebase), and Sonoff pow R2 with active mqtt (tasmota firmware).
A little more will be showing the tensions of each of the S
RikH likes this post
Layout update
tamkov likes this post
battery upgrade
and grafana reports !
Korishan and ajw22 like this post
inverter updated
cowpen likes this post
