Finally bought a Batrium BMS
#31
(09-19-2019, 11:47 AM)cadric Wrote:
(09-19-2019, 11:36 AM)HughF Wrote: You need an mppt controller that is supported by the batrium canbus system so that you can command a reduced charge current when you are balancing.
Or, you could ac couple your panels and use Eltek flatpacks to charge your batteries. Unsure what you could use to glue the control logic together, I have zero experience of AC coupling, because I'm totally off grid.
Ok, that means it needs further development and equipment to get what I want.
Canbus is the trigger here.....as I see it.
thanks again.
cadric
Or, just put fans on your mons and use the batrium 'cooling required' output to switch the fans on. Don't run too long an absorption time, I use 20 mins which is enough for me (Sean will advise a longer absorption time if you have a reduced current when balancing, which if you can do in the future, do that)... and make sure you set your float voltage at a suitable voltage which I can't advise for your chemistry as I use LiFePo4
#32
(09-19-2019, 12:39 PM)HughF Wrote: Or, just put fans on your mons and use the batrium 'cooling required' output to switch the fans on. Don't run too long an absorption time, I use 20 mins which is enough for me (Sean will advise a longer absorption time if you have a reduced current when balancing, which if you can do in the future, do that)... and make sure you set your float voltage at a suitable voltage which I can't advise for your chemistry as I use LiFePo4
Yes, good recommendation, fans is the first thing to do, now.
Absorption time? what is it exacly, and where do I set this feature?
2. Offgrid System 09.2019 7,5 kWp: 25 x 300Wp Solarworld (5x( 3S + 2S )), 2x PIP-5048MS, Batrium WM4, 1st Battery Bank: 840 cells in 14S60P with 80Ah cap in use, 2nd Batterybank with 14S60P in build.
#33
Absorption time is the amount of minutes that the charge controller spends in the CV phase, at your charge setpoint (56v for you iirc) whilst the current drops down and the last 5-10% of capacity is pushed into the batteries.
If you are happy to charge to a lower %SOC then just set a lower absorption setpoint and a short timer, it will then drop to float and the sun will carry your house loads whilst maintaining the battery at the %SOC until sundown...
#34
(09-19-2019, 02:36 PM)HughF Wrote: Absorption time is the amount of minutes that the charge controller spends in the CV phase, at your charge setpoint (56v for you iirc) whilst the current drops down and the last 5-10% of capacity is pushed into the batteries.
Ok, now I see, it's a parameter to be set in my Inverter, but not under absorptin time, on Watchpower it's called Max. Charging Time and set to 0.
It seems I need to set all the parameters in the Invereter right, at first.
thanks
cadric
#35
Be careful how you wire the fans up if you are going to use some kind of transformer to 12V for fans. Trust me I learned the hard way. As a result Batriums web site has more up to date information on just how to do this...follow it closely.
#36
(09-20-2019, 01:28 PM)Headrc Wrote: Be careful how you wire the fans up if you are going to use some kind of transformer to 12V for fans.  Trust me I learned the hard way.  As a result Batriums web site has more up to date information on just how to do this...follow it closely.
Hi Headrc,
thanks for the reminder, but I will go a different road, I think.
As I already have one fan for exhausting the warm air in the shed and one for supporting my Pips with cool air through a seperate channel, I will use a Sonoff device for the existing fans, as they already are 230V and for every additional fan device. So they will be completely unconnected from the WM4.
I will also add ds18b20 Sencsors on several positions, incl. the Cell packs, for this purpose. But that is further improvement.
regards
cadric
