Threads: 27
2
Total Cells:
Total Capacity: 0.00 kWh
For efficiency sake ...can someone please tell me the of Din Rail that Batrium is using for the Expansion board mount. Is it Type O, C or G. Also, what is the style I should look for for those plug in connectors for Batrium products .... I just received an Expansion board and I do not know if it is their custom but I received none of those plug in connectors for the Expansion board. Thanks, Richard
Threads: 12
10
Total Cells:
35x7.5mm rail fits - all types - I'm fairly sure all of the expansion boards we've purchased have come with the plugs, perhaps they mistakenly forgotten to include them.
Threads: 27
2
Total Cells:
Thanks Sean ....I don't know. LOL I don't want to ruffle any feathers but no I did not get any connectors at all with the expansion board. So who is the mfgr or the name of taht type of connector so I can get a couple. And thank you again for your kind offer on that expansion board previously.
Threads: 27
2
Total Cells:
OK ....I found the connectors ...they are by TE connectivity.
Threads: 27
2
Total Cells:
Scratch that ....looking closing at the TE connectivity I am not sure if they are a direct fit. If anyone knows the direct fit for the Batrium plug connectors please give me that ...I would like to get these ordered asap.
Threads: 12
10
Total Cells:
08-10-2019, 06:16 AM
(This post was last modified: 08-10-2019, 07:30 PM by Sean. Edited 2 times in total.)
Edit - 3.5 pitch screw plug terminals
These appear to be Alibaba's Pheonix Contact clones, the following is on the housing, which will enable you to identify the as fitted or a better quality Pheonix Contact original.
KEFA KF2EDG
KA(B)
3.5
Threads: 28
86
Total Cells: 29600
Total Capacity: 146.46 kWh
If you havent got the connectors you should contact Batrium... They should ship them directly if thats the case.
YouTube /
Forum system setup /
My webpage Diy Tech & Repairs
Current: 10kW Mpp Hybrid | 4kW PIP4048 | 2x PCM60x | 83kWh LiFePo4 | 10kWh 14s 18650 | 66*260W Poly
Upcoming: 14S 18650~30kWh | Automatic trip breakers, and alot more
Threads: 27
2
Total Cells:
I definitely did not get the connectors ....but waiting at least another week to get them from Australia is something I would like to avoid. But I also do not want to go to the expense of buying connectors that do not work. Looking at all the connectors I could find last night indicates that they certainly can be different.
Threads: 28
86
Total Cells: 29600
Then contact Batrium so they can tell you what connectors it is. Thats what I would do...
YouTube /
Threads: 27
2
Total Cells:
I will contact Batrium of course ...but once again it is the weekend ...and for that matter I had another question I sent on Friday ....mid day their time that I have not received an answer yet. I just thought someone might know so I could order some and have them shipped out first thing Friday morning. If anyone does ....please reply otherwise I will just have to wait on Batrium's response and try to get them ordered ASAP.
