2A discharger to test my prismatic cells
I am about ready to start testing my heap of prismatic cells.
I can charge them with my lipo charger, but discharging is a problem.
I want to capacity test at 2A. Anyone advice on a decent tester? Preferably not too expensive
(08-16-2019, 05:19 PM)Ivo Staelens Wrote: .........I want to capacity test at 2A. Anyone advice on a decent tester? Preferably not too expensive..........
Ivo,
First define expensive.If you earn 10,000 a year 100.00 is expensive.
If you earn 100,000 a year 100.00 is not too expensive. Tongue
If you are in the later then the Icharger x6  at ~120.00 is a very good unit.
Besides also charging your batteries (which you already have taken care of) it will discharge your batteries with settable parameters and log it to a sd card or your PC.
Last count as of 01/23/2020
For Info Google Drive
I bought this
Wolf likes this post
Perfect! Big Grin
Ivo Staelens likes this post
(08-17-2019, 01:56 PM)Wolf Wrote: Perfect! Big Grin
Thx!
I bought a similar one.
With discharging stay with it.
I let that thing discharge overnight, to see what the total capacity of the pack was.
Next morning i found a pack discharged to 1.6v!
https://www.aliexpress.com/item/32883863...4c4dB8D0wO
Maybe yours has a real cut off or i have to look better into his program, i set the cut off at 3v.
But it only gives a warning signal.
(08-18-2019, 10:43 AM)100kwh-hunter Wrote: I bought a similar one.
Should be possible i guess
To be at the safe side.
I check it again and i put a timer on it and see what happens in 12 hours.
The original post was for a 2a discharger. It occurs to me to share that I sometimes use my OPUS BT-C3100(s) where I put in dummy (taped off) cells to hold in nickel strips joining all 4 connections out to +/- that I connect to a pack. This gives up to 4a charge/discharge - with the features of the OPUS - e.g. auto-stop at 2.8v etc.
Yes you are right, for two amp discharge you could use some zb2l3 with a resistor.
https://www.aliexpress.com/item/32952122...4c4dRrZ0qn
If you are going to buy some, give me a pm first, i dont use them anymore.
