ben teker
New member
- Joined
- Apr 9, 2019
- Messages
- 16
dasKonzept:dasPil #2 -> 12V battery with weakest kept cells
[size=small][size=small]3s16p - 48cells - 32[size=small]Ah[/size][/size][/size]
[size=small]avg 2020mAh (min/max: 1952/2053mAh)[/size]
12.3Volt - 3x 4.1 V -> 0.398kWh
3x 2.5 mm copper twisted busbar (3x AWG 14?)
[size=small][size=small][size=small]fuse wire atpositive poles,fuse wire at negative poles[/size][/size][/size]
[size=small][size=small]busbar preparation[/size][/size]
[size=small][size=small]3D printed support - great helping hand for shape, positionand solder[/size][/size]
[size=small][size=small] [/size][/size]
[size=small][size=small]fuse wired both sides[/size][/size]
[/size][/size]
clear ground spacers
3D printed clip-on
[/size][/size]
benteker said:dasKonzept:dasPil #2 -> 12V battery with weakest kept cells
3D printed clip-on
