3.2v Sinopoply 12 volt question
I have 16 Sinopoly batteries. I was going to go 48v, but now I'm keeping it 12 v. Would someone tell me how it wire this please.
I have an Idea but I don't want to make a mistake. I'm thinking 4 goups of 4, but now sure how to wire those together...
Btw they are 200ah...I also have Batrium BMS on the way...this will go in and RV 5th wheel.
Thankyou
Assuming it's all LiFePO4 cells, the 4 groups of 4 should be fine.
Wire each group in series to get 12 volts. (in other words use 4 cells to create a 12v battery)
Then wire each 12v group (battery) in parallel with each other to increase the capacity.
If all these cells are new, you can probably get away with 4 BMS mons and add more only if you see balance issues.
(08-28-2019, 01:19 AM)Crimp Daddy Wrote: Assuming it's all LiFePO4 cells, the 4 groups of 4 should be fine.
Would I wire the Bms and Inverter to the + of the first cell and - of last cell? I wish I could see and actual diagram of the exact wiring...Thank you so much I know series is + to - but still not sure how to connect the 4 together.
The inverter doesn't "really" matter, but the rule of thumb is you connect Pos first then Neg.
For the bms however, it does make a bigger difference. Not wiring in the right order could blow out the bms. So this one you should wire from Neg -> Pos as well. Also to note, it's a good idea to connect the balance wires "before" connecting the main power leads.
18 User(s) read this thread:
Sean (08-28-2019, 12:19 AM), Darrel (Today, 02:16 AM), 100kwh-hunter (09-08-2019, 07:41 PM), Rhoos (08-28-2019, 01:30 AM), RikH (09-02-2019, 05:59 PM), ajw22 (08-28-2019, 08:19 PM), Generic (08-28-2019, 02:09 AM), Riplash (08-29-2019, 12:13 AM), Ibiza (08-28-2019, 07:04 PM), Redpacket (08-28-2019, 12:57 PM), jonyjoe505 (08-28-2019, 02:30 AM), Crimp Daddy (08-28-2019, 09:21 PM), gpn (08-28-2019, 03:56 PM), Geek (08-29-2019, 02:44 AM), jdeadman (08-29-2019, 01:05 AM), PAF (09-01-2019, 11:53 AM), Korishan (08-28-2019, 08:49 PM), railcon56 (08-28-2019, 09:00 PM)
