Queen Battery QB26650-2300 LiFePO4 cell's test + comparison to A123 ANR26650M1B
Video
QB26650-2300 is the second LiFePO4 model from Queen Battery. The 2500mAh cell i tested recently and i'll compare the two QB models to A123 Systems ANR26650M1B Grade A and Grade B cells.
[Image: 271173_original.jpg]
[Image: 87638_original.jpg]
[Image: 210421_original.jpg]
[Image: 209931_original.jpg]
I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 25±2°C. To be sure in results i've done each test minimum twice (usually 3-7 times).
Queen Battery QB26650 2300mAh
This cells looks like the 2500mAh, the only difference is the capacity mentioned on the heat shrink tube which tells us only the model, capacity and nominal voltage.
[Image: 270621_original.jpg]
Queen Battery QB26650 2300mAh has the following specifications according to its datasheet:
Typical capacity: 2300mAh (1C discharge)
Minimum capacity: 2300mAh (1C discharge)
Nominal voltage: 3.2V
Charge end voltage: 3.65V
Standard charge current: 2.3A (1C)
Charge cut-off current: 46mA (0.02C) (100mA used)
Cell's surface temperature during charging: 0-45°C
Discharge cut-off voltage: 2.0V
Cell's surface temperature during discharging: –20-60°C
Max continuous discharge current: 46A (20C)
Max short pulse discharge: 92A (40C)
AC impedance at 1KHz: ≤10mΩ at 50% SOC
Weight: 86g
Cycle life: аfter 1000 cycles at 2.3A charge/2.3A discharge (1C/1C) the capacity should be ≥1840mAh (80% of initial capacity).
DC IR at 2300mA in fully charged condition was 6.1±0.4mΩ (measured using EB Tester Software's Resistance test feature).
Measured dimensions: 26.7mm (diameter) × 65.2mm (length).
Measured weight: 85.80g.
[Image: 271804_original.jpg]
Queen Battery QB26650-2300 capacity test results (I've done each test 5 times).
[Image: 271054_original.png]
Just look at those numbers!!! This cell is rated at 2300mAh but it's real capacity is more than 2800mAh - 500mAh or 22% more than declared! I've never seen anything like this before... Even at 20A it doesn't go below 2700mAh! The curves look excellent! This guy stays above 3.0V most of the time! It's not just impressive, it's fantastic!
Here is the video version of this test including comparison to 2500mAh QB26650 and A123 Systems ANR26650M1B Grade A and Grade B cells:
[Image: 271524_original.jpg]
Verdict
Queen Battery QB26650 2300mAh should be marked as a 2800mAh one. It's a fantastic cell! It costs twice less than the 2500mAh model and 3 times less than ANR26650M1B. Queen Battery warns that these cells should not be connected in series of more than 4 cells and the total number of cells in the pack should not exceed 60 but i don't know the reason of such a warning. QB26650-2300's IR is very stable and there won't be problems with extreme disbalancing. Whatever, I'd highly recommend this cell as a very low-price LiFePO4 cell with excellent performance!
