PIP5048MS external solution to switch to line mode?
Hi,
is there a way to externaly initiate switching from Battey to Line mode on a PIP5048MS inverter? Either with some kind of Programm on a raspi or some other equipment?
As I'm only using temprary Battery solution, and my Batrium is not connected up to now, I would like to have some kind of solution to switch from Battery supply to Line mode, when the Solar Power is not enough for the load any more and the Battery start to get drained.
regards
cadric
2. Offgrid System 09.2019 7,5 kWp: 25 x 300Wp Solarworld (5x( 3S + 2S )), 2x PIP-5048MS, Batrium WM4, 1st Battery Bank: 840 cells in 14S60P with 80Ah cap.
The PIP have built in settings that switches between battery and grid.
Just set the low voltage switch in the unit
But yes you can control it as well. Solar-sis that i have made can for instance be configured and do such work if you set it up
Hi daromer,
I will have a look at your system.
thanks
cadric
Hi daromer,
is there some kind of description for installing the solution or parts of it on to an existing system?
I have a RasPi running with some other stuff already and would like to use that instead of using an image.
regards
cadric
All is in the documentation. But its not easy to run since you need to know a fair amount of coding. Its not "push a button software" directly Smile
