Highstar isr18650-2000 mah
How can i tell if these cells are high discharge?
You would have to check the datasheet from the manufacturer. Those cells are your typical Chinese special. Unfortunately, you probably won't find a datasheet and I wouldn't even use them.
If you have a minute to take pictures, we can at least get them added to the Cell Database.
https://secondlifestorage.com/showthread.php?tid=2592
here is a datasheet for a similar cell.
might be of some value.
.pdf   File-1499753795.pdf (Size: 8.61 MB / Downloads: 272)
(09-29-2019, 01:47 PM)ocaluptous Wrote:
(09-05-2019, 11:32 AM)mike Wrote: You would have to check the datasheet from the manufacturer. Those cells are your typical Chinese special. Unfortunately, you probably won't find a datasheet and I wouldn't even use them.
I think you forgot to add the file. ???
(09-07-2019, 07:26 PM)kc8adu Wrote: here is a datasheet for a similar cell.
Hey mate, thanks for the PDF was loking exactly for this levels.
Regards,
L.Smith https://dltutuapp.com/tutuapp-download/ https://showbox.run/ https://kodi.software/
