My little grid tied system with tesla batteries
Hi @all,
this is my first real post to this board. I read a lot here and come to the conclusion to build my own little
grid tied system ..... but with used tesla model s batteries. I used a Victron Multiplus II with a Simp BMS in combination with a
fronius solar inverter and a 3.5 kw solar array. As pictures say more than 1000 words: here they are Smile
The system works quite will even with the full load of about 5000 V/A. The current draw is more than 100 Amps then but
the components even don't geht warm.
Thanks a lot for all the informations i got from this forum !
greetings from germany
Jens
hbpowerwall, stevelectric, camthecam like this post
Very Cool!
hbpowerwall likes this post
Nice! So you feed 5kW from battery to grid after sunset?
Looks great mate, well done!
(09-16-2019, 06:49 AM)stevelectric Wrote: Nice! So you feed 5kW from battery to grid after sunset?
No, a max of 5Kw available to satisfy the local demand.
No .... both packs combined are more than 10 kW/h.
The inverter is programmed to serve my local demands. Excess power (if we are using more then 5 kw) is provided by the grid.
This is the case if my wife is using the dryer and washing machine in parallel.
There is a 3 phase meter on the grid side. In germany we have phase balancing meters. My inverter is on phase L1.
If i use let's say 500 Watts on L2 and L3 i can provide 1000 Watts to L1 (trough the inverter) and will not be billed for the energy on L2 and L3 -> L2+L3-L1 = 0
Jens
(09-19-2019, 04:38 AM)hbpowerwall Wrote: Looks great mate, well done!
thanks a lot Smile
Was my first time starter project  ..... will be enhanced to a 3 phase system in near future.
Jens
Nice job! You must be the same stxShadow I see on the TeslaBMSV2 github!
(10-07-2019, 11:42 AM)Bobby Wrote: Nice job! You must be the same stxShadow I see on the TeslaBMSV2 github!
might be possible Wink
sadly the owner of the github repository is not answering any comment.
cu
Jens
PS: Did you manage to compile the source now ? if not a can send you a pre compiled version.
Never got it compiled with the restart function working, though that's not a big deal. I'd love to learn more about your setup here, though. I'd like to stay grid-tied, but the inverter I have to pull power from the batteries it's for off-grid use.
Hi stxShadow, can you send me the compiled SimBMS file you are using with your setup.
